received today I2.2:00 Worked, battery discharged, put it on charge, heavily to Gain 14. basking% included a watch and left on charge. Disconnected themselves. Now do not react, nor the terms nor the battery didn’t show. FlashTool defines.
I recommend you use a better translation tool. I’m not sure what you mean here…
@1113 тебя очень трудно понять но видел твой пост по русски, попробую перевести. А тебе надо найдти другой переводчик. Это google translate?
Have seen here his post in russian, so will try to translate.
He received the i2 watch. After 2 hour battery was empty and he put it on charge. When the watch started to get really hot, the charge was only at 14%, he switched the watch on and let it charge further. After some time the watch switched itself off and do not react since then and does not show anything.
it is possible to see the watch in the Flashtool
One post under this post i see he has written, that Flashtool stopped to see it and in the device manager he see now only unknown device.
I don’t understand what he means with “With kredla food goes 0. Battery Charging. does nor warm.”
