This is a known problem with PRIME watches.
There is no problem with the motherboard button.
But the rubber seal on the pushbutton housing in the watch case is the problem.
If you have an experienced mechanic hand you are not difficult to repair.
- The watch must be completely disassembled.
- Remove the inside locking ring of the pushbutton and push it out of the housing.
- Apply a thin layer of silicone grease or silicone oil to the hole and the rubber seal of the pushbutton.
- You then assemble and use it happily.
