Apr 9, 2018 14:14:30 GMT 1maxilimian said: Found a great apps on playstore, to access phone calls, sms, camera, music from your watch to the phone in one apps, the apps called watch droid phone, you should installed it on the phone and you should install watch droid assistant on the watch, paired the watch source & viola ... happy trying
Very good.....
A little problem is a battery drain and the Bluetooth call start, but audio speack from primary phone onlyā¦
Any help?
Thanks!!!
Guys, Watchdroid is a well known app, sometimes - not often - with battery drain, sometimes with lost BT connection, not often as well. I use it since several monthes and I'm happy with it. But: This app was not implemented for BT calls, it's not a bug! Watchdroid simply doesn't offer that feature
Mar 21, 2018 22:02:28 GMT 1jackrussell said: Thanks a lot Firefoot007, now it works perfectly with your tips.
At the moment i'm having some troubles syncronising phone contacts, but i'll study a little bit more.
I've used firmware linked in previous post and disabling "preloader" it works really good. Thanks everybody, if i can help some other users just ask.
Hi jackrussel, did you flash the 1stAQR-LAUNCH-I4P-1601-Fitness-HEHUI-BT-NHT-V01-20171121.zip firmware on your hehui DM368 to get the Bluetooth call functionality?
I did and it worked.
Use download mode and dont select preloader. Good Luck
Ahsan
Apr 16, 2018 22:49:01 GMT 1killerelite said: Hi jackrussel, did you flash the 1stAQR-LAUNCH-I4P-1601-Fitness-HEHUI-BT-NHT-V01-20171121.zip firmware on your hehui DM368 to get the Bluetooth call functionality?
Ahsan
Thank you, flashed the firmware and its working like a charm!
You should do a factory reset if you did not flash the pre-loader.
It will work if you donāt but some crap gets left behind from the previous system and may effect your battery life.
Hi, what kind of FW or specific FW Can I use if my Watch uses the FW: AQR-LAUNCH-I2-1602-CAMERA-Fitness-NTH-V01-20170914? I will hope your kind help and wait your comments. My watch is an ColMi i2 (2GB ram and 16GB storage, with camera).
Jun 16, 2018 8:04:21 GMT 1saktamc said: Hi, what kind of FW or specific FW Can I use if my Watch uses the FW: AQR-LAUNCH-I2-1602-CAMERA-Fitness-NTH-V01-20170914? I will hope your kind help and wait your comments. My watch is an ColMi i2 (2GB ram and 16GB storage, with camera).
Regards.
Check if it is the i4 air or i4 pro you can use their firmware which has the BT calls app
Regards.
My watch isnāt an i4 Air but is an ColMi i2 that i understand that is practicaly identical that i4 Air, but i donāt know if the FW of i4 Air works with my i2, it may be works?, other question is if for error i brick my i2 the stock FW of i4 Air help me to unbrick it. What do you think?
In this video i see that my whatch supports bt calls but my watch dont have the bt call app like the watch in video (my watch is the same that is in the video).
Any comments? How do you think that the person on the video get the ColMi i2 with bt call alredy installed?
i know it isānt the i4 air or the i4 pro it is the same watch just different name you need to be sure which one is like yours and which version of firmware it has and you can use it on your watch.
Oh! I see, thanks a lot, i will check the FW of the i4 Air that is like my ColMi i2, one more question for you Soniasophie9697, where i can find the FW with bt call added for the i4 Air for 2gb - 16gb?, because i only saw in this forum the FW for the 1gb - 16gb version. If you can help me i will be glad.
