Real Bluetooth phone calls from your watch running Android 5.1 ONLY
Mar 6, 2018 17:48:33 GMT 1 yawa said:
Mar 6, 2018 16:29:51 GMT 1 firefoot007 said:
have you looked in FW section i think it was updated with new firmwares for all i4 brands.
Yes, soniasophie9697, I have. And I’ve found this link (MEGA) which is a collection of I4 FW’s starting with 1602. BTW, still no news regarding new FW’s for DM368? (we had talked about it in another thread).
Maybe try AQR-LAUNCH-I4P-1601-Fitness-HEHUI-BT-NHT-V01-20171121, because i am running this rom right now.
I would try it, but I haven't found the link to this FW so far. Could you provide it pls if you've got it? I used this one, but found only later FW's: mega.nz/#F!plYlCDwS!m1m3pnLhqswz90JkOS8NRg
/thread/1046/official-release-firmware-added-version
Many thanks! Cool, I'll give it a try
Yes, soniasophie9697 , I have. And I’ve found this link (MEGA) which is a collection of I4 FW’s starting with 1602. BTW, still no news regarding new FW’s for DM368? (we had talked about it in another thread).
will check:)
Does the I4 Air supports Bluetooth ā€œcallingā€ if I use one of the firmware on mega.nz/#F!plYlCDwS!m1m3pnLhqswz90JkOS8NRg
Thank’s
Hi Guys is there are any news regarding BT call using a Lemfo Lem5 Pro? Thanks
it is'nt up to us, it is up to lemfo and finow which for now they do'nt want to work with the software developers.
zsolt m
ricktop
it is’nt up to us, it is up to lemfo and finow which for now they do’nt want to work with the software developers.
zsolt m
ricktop
I was asking for the I4 Air because the I4 was now supporting Bluetooth Calling so was wondering for the Air (with the camera) and not sure it supports it or not but well, went with the LES1 to make sure.
zsolt m
ricktop
I have an I4 Air and just to clarify your comment. TheBT Call firmware for the I4 Air available on this site is not ā€œfactoryā€ firmware. And if you install it on an I4 Air and it does not work, there is no known factory firmware available for the watch and it may be rendered useless. I have not seen any comments here where someone installed it and said it was great. Remember once installed it is all you have because as I read on this site that you cannot do an OTA update except from the standard firmware. You cannot do an OTA from these BT Call firmware updates that don’t come installed on the watch.
Good morning any news for Y3?
I use zeblaze thor. I also have successful firmware upgraded and so I can talk to Bluetooth easily without sim. One problem is the sound of the phone to me when I get a call or a call. Is there a way to set the vibrations or the vibrations and the sounds together?
Mar 1, 2018 14:15:16 GMT 1 firefoot007 said:
Yes you can try any I3 or any I4 fw (with HEHUI) in DM368. I am currently running fitness one in my DM368
Hello, is it possible to flash this firmware on Domino DM368 512kb/8Gb ? i have tryed to add bluetooth calls but smartwatch didn’t boot, so i have reflashed original domino dm368 firmware. Thanks for support and possibly to anyone can give link to correct firmware to flash.
The firmware i have downloaded is: 1stAQR-LAUNCH-I4P-1601-Fitness-HEHUI-BT-NHT-V01-20171121.zip (dowloaded here: mega.nz/#!Z5YyGZCT!zrz1VHkAOli5Frk6M5aGOno3S_Lp9BbvUI2K1-1q1aY)
Take a look at this thread some comments before. I’ve already tried to flash AQR-LAUNCH-I4Pro-1602-Fitness-HEHUI-NHT-V02-20180131 on my DM368, but it didn’t work for me. There was a proposal (and a link as well) to another (1601) firmware, but I didn’t try it yet. I would appreciate if you would report here whether you had success with some version. Thanks!
Hello Yawa, as posted before i have tryed the 1601 ā€œfitnessā€ version on my dm368 HEHUI with 512kb/8Gb memory, but unfortunately the watch didn’t boot; i don’t know if the I4P stay for I4 Pro, but i had to reflash with original dm368 firmware.
Maybe smartwathes have different memory sizes and for this reason didn’t boot. Hope someone can clarify the situations about DM368, i just need to call/receive via bluetooth, i don’t care about OTA updates. Thanks
Mar 21, 2018 15:06:28 GMT 1 jackrussell said:
Hello Yawa, as posted before i have tryed the 1601 "fitness" version on my dm368 HEHUI with 512kb/8Gb memory, but unfortunately the watch didn't boot; i don't know if the I4P stay for I4 Pro, but i had to reflash with original dm368 firmware. Maybe smartwathes have different memory sizes and for this reason didn't boot. Hope someone can clarify the situations about DM368, i just need to call/receive via bluetooth, i don't care about OTA updates. Thanks
is your watch with 512mb ram and 8gb storage? the 1.4"?
I dont know why is it not working for you guys. It has been around 2 months since i have this BT call firmware on my watch and its running okay, some glitches here and there with notifications. Remember dont select preloader when flashing.
Best thing was customised fw for DM368 just like KW88 but i dont think its possible.
Yes, it’s 512Mb and 8Gb storage. I have tryed KW88, KW98 and KW99 firmwares and phone boot, but screen is flipped 180°, just upside down.
I will follow firefoot007 suggest, and try to flash 1stAQR-LAUNCH-I4P-1601-Fitness-HEHUI-BT-NHT-V01-20171121.zip deselecting preloader flag.
firefoot007 what firmware are you using on DM368 to have bluetooth calls? the same i’ve mentioned or another one? Thanks in advance.
Thanks a lot Firefoot007, now it works perfectly with your tips.
At the moment i’m having some troubles syncronising phone contacts, but i’ll study a little bit more.
I’ve used firmware linked in previous post and disabling ā€œpreloaderā€ it works really good. Thanks everybody, if i can help some other users just ask.
Hi All, I’ve paired my AllCall W1 with iPhone 7 and I’got na Issue. Bug is, that every time when i pickup call on my phone with marked phone as a microphone, call is redirected via BT to watch. Can You help me with that?
