Rainbuvvy Smart Watch
Been away quite a while. I recently acquired this watch, and wondered if the bootloader can be unlocked and a custom ROM Installed?
What’s Rainbuvvy model ?
100% its a no. Android 8.1
No downgrading to android 7.0?
why would you even downgrade to that version
So I could unlock the bootloader and install a custom ROM.
unc it’s not the same like before, new watches nowadays runs on spreadtrum (as long as you have 2 buttons) and there are no one click root solution, however there are ready-made a10 roms with root enabled (if you have rounded display forget about it anyways)
So no way I can root this watch, and install another ROM?
if your watch is rounded why bother, 90% of the apps won’t be useable anyways
My watch is rectangular. A custom ROm would at least remove to bootloader music.
well then if you’re lucky there are working GSIs of crdroid that might be compatible with your device; i can’t help much further here on this fourm but the guide and files are within a telegram channel
Can you provide more details, perhaps via private message? I do not use telegraph.
