Hi everyone!
At first I want to thank this community for existing
Due to a flashsale offer I am now owner of my first FAW, the Blitzwolf BW BE1
Tbh I really like this watch amd I would love to replace it with my Wear OS device, still testing and trying to figure out everything.
I have a particular question concerning Whatsapp Web: There are many apps supporting the Web Version, like tablet messenger etc. Unfortunately none of these is working on my device, it seems like the app is only loading " half", and on top of that I can´t really close the ads.
I already enabled 3rd-party-apps. Has anyone got a tip what do?
My second question is concerning Droid watch: Is there a way to summarize group chats notifications?
Hi thanks for your quick response! Yeah I know and already have used the aqaure mode…So the app is loading with it navigation bar, but the field where the qr code appears stays empty. I will try to film it later.
I forgot to say: Normal whatsapp is working fine, I switched my for testing on my watch, it works fine. But as you know I can`t use it on my Smartphone then
You are right. I noticed a few days ago that tablet messager and some others are not longer working on android 7.
On Android 10 it works still fine.
I don’t have any solution for android 7 atm. I’ll let you know if I find a way.
OK, in fact is Tablet messenger V738 the newest running version. But if I download the APK of this version from APKpure, I get a message from my watch that this app is not compatible…
What ever, I’ve copied it from one of my watches and this APK works:
So I am definetly more ahead than before ^^ I installed the 738.apk, and I even get to the point where I can scan the QR Code. After that the screen is merely loading and nothing happens, even after 5 min. I gave the app access to every and the ability to run in the background. I`m so close, but that seems the last step
Unrestricted data wasn`t enabled, but even after that it won´t work. What I recoginzed that after every scan the text “please scan again” under the WA Scanner on my phone… storage acces is enabled
Ok it worked then after restarting and accessibility for zooming the code. It is now said that my Internet is too slow, though I am in WLAN. I ll try to fix that and maybe have a look at other apps, gonna write here if I had succes
