Question: Does anybody know, whether the faces for the K18 can be used for the Colmi vs115 smart watch (https://www.youtube.com/watch?v=PTYIPdNf25U)?
I own a K18 with a ton of watchefaces (done by myself with the “clockskinmaker”), and befor i buy Colmi… ;o).
Thanks&Best regards…
Chris
@R_Chr
Yes you can. This is an IQI I4 under a different name. The watch is quite capable of using the watch faces although you may find that the watch face engine has been updated quite a bit since the K18. I still have my original K18 from December 2014 I would advise you to go onto the tech support forum. Link is in the first post pinned here. There you can find details of a launcher you can also install.
But, right out of the box the i4 actually has a Clockskin folder you just dump all your faces in. Well, the new firmware update in a few days will have.
So, you’re all good to go
@Fotis_Koutroulis Yes ?
i have a colmi vs115 too, do hoy know if í can change the firmware to an i4 one in order to update?
@Rafael_Perez it is the same firmware - as long as the exact specifications are the same. Including the screen, storage and memory size
