Let me explain it this way: When I plug the smart watch cable into the computer, the computer says it does not recognize the USB device, that is, the computer does not accept the smart watch. I will send you a photo separately so that you can see it separately. Please help me on this issue. It does not accept.
You should try another USB cable and another USB port.
Uploading: IMG_20250222_150545.jpg…
This is what my smart watch looks like
There is still no photo to be seen, but I don’t need one. I know 100% that it can be flashed, a locked screen doesn’t change that. If you get the message that the USB device was not recognized or is not working, there are three possible reasons:
1- the cable is defective
2- the USB port is bad
3- the USB drivers were not installed correctly. The USB drivers should be installed on the PC “as administrator”, otherwise it won’t work with some versions of Windows.
I wonder why it doesn’t detect my smart watch, I don’t know if what you say is true.
Yes. Two contacts are for charging, the other two for data transfer.
Let me get a new cable
But I don’t know, it works when I plug this cable into the charger as a device, so should I buy a new cable?
First, check whether you have installed the USB drivers correctly. Did you install it as an administrator? Do this first.
Also clean the contacts on the watch, it is best to use some cleaning alcohol for this.
Finally, there is the possibility that the USB port on your computer is the problem. Try other ports.
Only when all of these problems have been ruled out would I recommend a new cable.
It must be turned OFF to flash. It will also flash with battery dead. I dont believe you are following the procedure
Look sir, let me explain the situation like this, I have set up the flash files, they are all set up on my computer and I am plugging the cable of my smart watch that I will flash to the computer.Is it because the computer does not recognize the smart watch? That’s why I am saying it, why does it not recognize it? But I understood that the screen wallpaper of my smart watch has changed, most likely my smart watch has been reset.Since it was reset, there are probably only 2 screens still on the screen.So I don’t know if flashing is the solution.
IF the drivers are installed correctly , the watch is OFF and the cable is not damaged i have no idea why the flashing will not work for you following the standard procedure. What is and is not on your watch screen is not important and i have no idea why you repeat this ? And as it should be off for flashing i do not understand
I changed the cable as you said and made a new cable, I flashed it and then formatted it, but my smart watch is not working now I plugged it into charger, what should I do for the screen to work?
I think this is the end of the road for your watch
Well, why would my smartwatch end? Before flashing the smartwatch, the screen was on, after flashing it, the screen turned off completely, but I did flashing features etc. Why didn’t the screen turn on?
If you flashed correctly with the correct firmware and the watch no longer boots when charged with a working charger i have no more advice. Sorry
Well, then it was probably the wrong firmware. The watch is not lost, but the correct firmware is needed. Unfortunately, this is the only one I could find.
In fact, you couldn’t use it before flashing and you couldn’t use it after flashing, so you haven’t lost anything.
It’s the wrong firmware. That’s all.
All you need is the right firmware. I will have 2nd look if I find another one that might work.
