Problem with notifications lost when screen is locked
Hi everyone,
I’ve noticed that when the screen lock is enabled (tested through pin or face recognition) the notifications use to get cleaned (and lost) when the screen is unlocked.
This occurs on the Lemfo Lemp, with Android 9.1. Not sure if occurs on every 9.1 FAW or just on this one.
If I disable the screen unlock, I receive notifications normally.
Also, it occurs after some period has taken time after lock the screen. Not if I unlock the screen after a notification arrives immediately or a few seconds/minutes after being locked.
Can this issue/bug be fixed?
Thanks guys
Have you checked the option to wake screen for notification?
Its in the display settings.
Another point to remember is that this won’t work in power saving mode or “sports” mode.
You also need to check the notification permissions for every app that you need to see this working for.
Personally I use an app called “heads up notifications” which is very customisable as long as you set the permission to allow “display over other apps”
Hopefully it will work for Android 9.
Bingo at first shot!!!
By enabling the first option you gave me, it’s seems that solved the problem!!
I still have a few hours checking it, but no more failures had taken place since then.
Everything else (permissions, battery, power saving options, etc) already was tested before without impact. It seems that enabling the brightness screen when a notification arrives was the solution to this problem.
Thanks man!!
Excellent, good to hear :+1:
