I have problem with Clockskin.After i choose Always use Clockskin ,watch after browsing thru menus reverts to original home menu.
It repeats asking me to choose Clockskin menu
Please anyone?
I am afraid I did not understand you. Can you describe your problem in more detail?
are you trying to use Universal Launcher?
Yes, i’m suspecting he tries to use UL and the window to choose the launcher keeps on appearing…
First : make sure you use the last UL version.
Second: if it’s an A10 watch, then UL is not working good on this
Third : make sure UL is not being closed by battery cleaner…
Thank you Eric .It is lem 12 pro,A10 watch.I will try batery cleaner
