Managed to install the clockskin coco on my lemfo les1. after i launched it, the face appeared to be slanted and truncated. not able to view the full clock face. Please help. Thank in advance.
You must disable the square zoom vies, or try another skin if this one does not work.
Hello Ricktop great effort, same problem in zeblaze thor with clockskincoco 2.2.2 works fine after installing but when restarting or turning off the clock faces appear out of center (down and to the right). Also weather is not updated sometimes works if you change the clock face.
I have also tried with clockskin 2.2.1 and 2.2.3 clean install and factory reset but the problem continues.
Jul 11, 2017 19:42:16 GMT 1 jaeson said:
Hello Ricktop great effort, same problem in zeblaze thor with clockskincoco 2.2.2 works fine after installing but when restarting or turning off the clock faces appear out of center (down and to the right). Also weather is not updated sometimes works if you change the clock face.I have also tried with clockskin 2.2.1 and 2.2.3 clean install and factory reset but the problem continues.
Hi my friend you have to deselect first the zoom view
Jul 11, 2017 21:44:50 GMT 1 jim10 said:Jul 11, 2017 19:42:16 GMT 1 jaeson said:
Thanks friend, I'll try.
Jul 11, 2017 6:30:34 GMT 1 ricktop said:Jul 11, 2017 1:04:45 GMT 1 lee said:
Thanks Rick. It works. But not able to receive notifications from my phone. Is there a way to resolve it? Pls advise. Thanks.
So I had this same problem, and had to set the button back to the main watch function. however, now that this problem is fixed, I can’t set the button to bring up watchclockskin. Whenever I hit the button, it brings up the default watch face.
Jul 12, 2017 2:51:49 GMT 1 lee said:Jul 11, 2017 6:30:34 GMT 1 ricktop said:
Have you activated the notification toggle in the 2sd setting screen ?
Jul 17, 2017 7:01:00 GMT 1 ricktop said:Jul 12, 2017 2:51:49 GMT 1 lee said:
I did, but still not able to receive notifications. Pls advise. Thanks.
Hi, This question may sound stupid to you guys but I am new user and bought LES1. May i know where and how to disable square zoom thing?
Aug 14, 2017 22:09:18 GMT 1 abhishekbafna said:Jul 12, 2017 2:51:49 GMT 1 lee said:
Hello you must leave the button pressed off and in the upper middle you will find the option to activate or deactivate the square zoom.
