Prob with Universal Launcher
hi ,
I just install UL on my new FAW with Android 8.1 to install custom watchface… But Steps not displayed always at 0000 value, same pb with heart rate.
Any explications??? Thx
I’m sure @Eric_Crochemore can help you with this
This problem has already been seen on some unusual watches. It looks like the services are not available at the standard address.
Moved to unsupported watches.
So no solution? :confused:
That UL does not display steps and other data on some non-standard watches is true, but it is also true that Apps downloaded from the PlayStore certainly read the steps and I gave photographic evidence in the Universal launcher topic, last post. @Eric_Crochemore himself was surprised by this.
yess i saw that steps app is ok, just have prob with watchface, also with battery level bar.
Maybe I didn’t explain myself, the images I posted show that various apps downloadable from PLAYSTORE read the steps (I have a CDS9), while Universal Launcher does not read the steps and consequently does not display them on the dials
yes a prob of UL i think, i tried severals versions (3.2, 3.6 and 3.7), same prob.
In fact, it’s not an UL problem, because it’s working on all watches which are supported here.
I will check if something has changed in the Android SDK…
What’s the apps?
For example this pedometer application, the one in the photo
or the other app as shown in the photo which is no longer on the play store:
Meerun
Thx a lot :wink:
Try to use universal launcher v4, it have sensor support for all smart watch in the world, by using a separate app that handle the sensor, if none is found, the app emulate a sensor by using accelerometer
It only works on square watches, for round ones you have to continue using U.L. v.3.7 with all its problems. It only works on square clocks; for round clocks you have to keep using U.L. v.3.7 with all its problems, one of them being that in order to at least read the weather, the clock must be in English :angry::angry:
UL was made by one of our moderators in his own time and for free ? Also with years of support. He should be thanked. Or do you think he should continue for free to help with your “ problems “
I wonder why it was limited to square watches.
I think the Jeffrey’s comment don’t have to be misunderstood, Andy.
It would be good not to mix comments on my Universal Launcher and on the stolen version 4.0. By the way, my watch is always in french and i have not seen issues on weather. Some details can help.
