Hmm. I have tried to update to FAW 1.1 after installing 1.0 - and problem. I cant send file to watch from pc (win7). After connecting to PC I see the new device PRIME2 - but after, inside folder - I see nothing. Memory is invisible. Of course, before update there was no problem with connecting. Reseting, installing drivers - checked with no effect. Any suggestions? yes, I know about BT or wifi
, but direct connecting is better and faster.
Done. I dont know how - but suddenly after another connect - memory appear on Prime2 device⦠But problem I see as closed.
Hello, you need to change the USB connection setting to file transfer, this only needs to be done once.
It is available under: Settings β Connected devices β USB
