I need new original rom.
/board/16/factory-firmware-downloads
Hello I have this error message
download this: /thread/125/d5-w612-firmware the updates you'll get via ota reset the watch and then start all over the flashing.
Hello come this error message.
do you know how to disconnect the battery?
Hello I have the battey switched off and on does not go
Have tried with differentiate firmware does not exist gives many
Origina ota firmware.
Dec 21, 2016 20:18:19 GMT 1 keoma said:
Hello I have the battey switched off and on does not goHave tried with differentiate firmware does not exist gives many
you can flash the x3+ firmware stock rom but without marking the pre-loader and see if you still get an error message.
Hello has not worked what I am doing wrong.
i wonder if it is hardware, let me check it and see if i can get an answer.
Hello
Thank you for your time.
Dec 22, 2016 13:52:15 GMT 1 keoma said:
Hello Thank you for your time.
hey, read this carefully some how it is like the rom does'nt suit the watch so look in the link to see how you can resolve your problem and i will help in anything you need.
Hi, I have the same problem, there is solution? Can anyone help us?
Thank
Sounds like w612 rom on newer w613 watch.
Hi
I resolved, Today on the N0.1 site I saw a new w613 firmware version that was not there yesterday, I refleshed with this and the clock running again.
Thank you all
Hello many thanks with this W 613 firmware works my NO.1 D5 Plus again.
