can anyone help me lemfo les1 I boot loop/stuck in the balloon image only.
how to handle it
how to handle it
You can flash the FW, it should return the watch to a working state. FW is on this forum, turotial is on our YT channel.
link please
Jul 24, 2018 11:37:03 GMT 1 ricktop said:
/thread/1036/les-stock-firmware-calling-version
You did FW upgrade ? Try again this should work.
You need to google that error to find out what is wrong.
Jul 25, 2018 11:43:44 GMT 1 abang said:Jul 25, 2018 6:48:42 GMT 1 RASC Moderators said:
I've searched Google but nothing
Jul 25, 2018 14:07:23 GMT 1 capt jon said:Jul 25, 2018 11:43:44 GMT 1 abang said:
I did a google search and the first thing up is this video from Mr. Ticks, Smartwatch Ticks YouTube channel that discusses how to fix an Android watch stuck in a bootloop. Which sounds like it possibly is your problem.
I tried it but it still didn’t work
if yes,
if yes,
3.have you tried downgrade and using firmware downloading only?
if yes,
Jul 25, 2018 14:56:51 GMT 1 soniasophie9697 said:abang
- have you tried to flash the watch again?
if yes,
- have you tried to disconnect and reconnect battery?
if yes,
if yes,
- can you give me a link to which FW you’ve tried and which watch you have?
Yes, I have tried some hardware such as: Z10-KY_HFP-BT-20171122, Z10-KY-V10-20170628, Z10-YFZ-V05-20170419, Z10-YFZ-V07-20170515,
Z10-YFZ-V09-20170713, Z10-YFZ-V10-20171011
I have already done
I have not done so since I do not know the link
ok will i send the link
after you’ll give me a link to the software that you’ve used i will help you trying to flash the right one and downgrade the firmware to see if that will fix the watch, just to be sure you are 100% sure that the watch worked for a while and then just stopped, right?
Jul 25, 2018 15:58:53 GMT 1 soniasophie9697 said:abang
2. version Z10-YFZ-V09-20170628
3. versino Z10-YFZ_HFP-BT-20171122
4. version Z10-YFZ-V09-20170713
5. version Z10-YFZ-V07-20170515
www.filefactory.com/file/3uod6wxqnhnv/Z10-YFZ-V07-20170515.rar
6. version Z10-YFZ-V05-20170419
drive.google.com/uc?id=0B_Rq6-Y3GsgkR2NocUlDZkQzZ0U&export=download
this is a video link when I use sop tools drive.google.com/drive/folders/1wdSUn-8pBZ5CRz0I5VI0iuCnaAkAkOw0
