What happened? Why is it upside down?
Also, the latest firmware for i4 Pro is falty. I can’t flash it so I had to use the second newest.
Is there anything I can do to flip the screen?
If it is upside down then you have flashed the wrong firmware.
Can you please tell me your exact watch model and the version of firmware that was on it before you flashed?
May 27, 2018 3:39:39 GMT 1 RASC Moderators said:
If it is upside down then you have flashed the wrong firmware. Can you please tell me your exact watch model and the version of firmware that was on it before you flashed?
The watchmodel is Iqi I4 Pro 2/16 and the firmware the watch came with is from february 2018.
I flashed: AQR-LAUNCH-I4Pro-1602-Fitness-NHT-V01-20170921
When trying to flash AQR-LAUNCH-I4Pro-1602-Fitness-HEHUI-NHT-V02-20180131 I get this error: ROM[logo] checksum mismatch: checksum_config[0xbe27] checksum_val[0xbf26]
That’s mismatch in checksum.ini file that is inside dir with firmware it’s safe to ignore. If I recall correctly this happens sometimes with newer version of SP flash Tool. If checksum error is only for logo.bin you can disable checking and flash
Just make 100% sure you are flashing correct firmware for your watch.
N.
Is there any other place where I can find firmware for IQI I4 Pro?
I managed to flash AQR-LAUNCH-I4Pro-1602-Fitness-HEHUI-NHT-V02-2018013 but the screen never woke up. It seemed to boot up correctly and sound worked too, but without any screen.
How can I go back to the firmware the watch came with?
Is there a way to get in touch with IQI?
I made a video showing the problem and how I “fixed” it.
try to flash older images from here
mega.nz/#F!plYlCDwS!m1m3pnLhqswz90JkOS8NRg
Sept 10, 2018 18:45:35 GMT 1 zerg said:
try to flash older images from here mega.nz/#F!plYlCDwS!m1m3pnLhqswz90JkOS8NRg
anybody tell me please how to turn back upside down screen back? Where is take correct firmware for my i4 air?
model i4 air i am try to flash few firmware but the problem is still present.
i am tryed to flash this firmwares yadi.sk/i/3oqT-fG44F1gPA
Nov 9, 2018 12:02:51 GMT 1 unkn000wn said:
model i4 air i am try to flash few firmware but the problem is still present. i am tryed to flash this firmwares yadi.sk/i/3oqT-fG44F1gPA
i am tryed
AQR-LAUNCH-I4Air-1602-CAMERA-Fitness-HEHUI-NHT-V01-20171121 and
AQR-LAUNCH-I4Air-1602-CAMERA-Boltt-Fitness-NHT-V1.0-20171122 and
MT6580__AQR__I4Air__I4Air__5.1__ALPS.L1.MP6.V2_SF6580.WEG.L_P76
/thread/2084/all-2gb-16gb-models-air solve my problem. thanks to RASC Moderators
Feb 18, 2019 4:55:49 GMT saktamc said:Nov 24, 2018 0:05:35 GMT unkn000wn said:
Hi, what firmware helped you solve your problem?
