Overheating on my prime
The watch is overheating causing the video to scramble and eventually fade out. Is there any cure for overheating on the prime SE?
Usually a watch can overheat when its pushed to the limit ie
Screen on , wifi on , gps on , bt on , data on etc , apps running in background .
Try to reduce where possible the above and see if it runs cooler
Thank you Tim, will do so and monitor results…
