A wireless OTA update for the Lemfo LEM7 with MT6739 Chip became available over night.
The new version is: Z285-LEM7-V1.5
Note: If you have TWRP (and possibly root) installed then the update will download and go into a boot loop to TWRP.
The solution is to use the SP Flash Tool to flash the stock recovery.img and the boot.img onto it.
Go to update and it will now update.
Then use the SP Flash Tool to flash the TWRP recovery.img and the patched boot.img to give TWRP and root.
I got into the TWRP boot loop, and selected to turn off the watch so that I could load the stock recovery.img and boot.img but on rebooting the update started to install but an error message came up.
I rebooted the watch but it only booted into the first boot screen and stopped there.
But I found that holding in the button turned off the watch for a short time until it rebooted into the boot screen again.
I used this fact to reinstall the full stock ROM with the SP Flash Tool by pressing the green down load icon, connecting the watch to my PC and holding in the watch button
It turned off and the SP Flash Tool caught the transition to off and was activated and the stock ROM installed
I then installed the update
