hello
Do you know where i can download the original firmware for the LEMFO LM12 ? (actually v7.1.1 and z32-lem12-v1.3)
I have some trouble with the touch screen (freeze)
thank you
hello
thank you
thanks ! i can install directly in local with about/update, or with flash tool ?
You’ll need the flashtool.
I needed the firmware lem12 ota can you get it?
How should I give you the OTA update (over the air)? Sorry, but I can’t. If there is an OTA update available, it’s shown in the settings.
Otherwise you can use the firmware I’ve posted above. But you’ll have to use the flashtool.
