And yet as far as i am aware this is the first one reported on this forum . But bearing in mind he dropped it surely most watches wouldnt survive a fall ? Unless you are lucky
I haven’t dropped it.
When i said “one fall” it’s to say the Horn fall.
Sorry, nor did I drop mine. I literally woke up with a broken watch. Complete garbage.
Yes, thats the 1st Prime with this problem I see. Can I have a look at the screws, please?
Did you possibly mean to say “fail” instead of “fall”. Big difference.
Thank you. Strange, the screws are looking good. They aren’t rotted…
I’ve fixed my broken horns with PVC glue from pipe assembly.
@eswiderski, Do you sleep with your watch on? Is it possible you were having a nightmare that a lizard got hold of your wrist and you were slinging it around hitting a bed post or something like that?
Well either way it shouldn’t break that easy. What would be really great would be if watch makers were using the kind of plastic that is used for gun frames like Glock, Walther and so on as that stuff is tough as steel. I’ve worked with ABS which is strong but if it’s too thin in a stress point it’s going to break.
