Jan 24, 2019 11:32:40 GMT 1maheshchandra said: I Received the Kospet Hope $g (3+32Gb) today
The wifi MAC address changes with each reboot on this watch
(the first 3 sets remain same while the last 3 are randomly changed)
so am not able to keep wifi mac filtering activated on my Wifi Router.
is it a hardware problem or software
It's a firmware issue.
What FW version are you using?
It should not be able to change WiFi MAC address
Ok, thanks.
This is very unusual for these watches.
It is a known fact that Android 7 has to have a fixed mac address because otherwise Google sign in does not work.
You are the only person I know of that has this problem
I will see what I can do about this. I have already informed the manufacturer.
If you can order yourself a data cable asap - we can flash the firmware.
Otherwise you will need to return it for exchange. Where did you buy it from?
I have ordered the cable but if its not definitely going to work
then I would like to replace the watch as still in DOA warranty
the bangood order number is 59897408
Jan 24, 2019 12:17:08 GMT 1maheshchandra said: I have ordered the cable but if its not definitely going to work
Ok, I’ll contact Kospet and let them know.
Because this is the first time I have seen this issue with the Hope watch I cannot be 100% sure that flashing firmware will fix it.
Apparently the watch IS SUPPOSED to have a permanent MAC address for WiFi.
This means that a batch of these may have been produced WITHOUT this and it is a production issue.
If this is the case then we will be getting a few more complaints
Anyway - we need you to open a dispute with Banggood and I will support it from my side.
Do you have any video that can show the mac changing on reboot?
You find that the MAC actually changes on every single “connect - disconnect”
