Hello, first sorry for the language since I use the google traslate, I have a problem with the connection of the zeblade thor to the PC with win 7 (both 32 and 64 bit), I tried on many PCs following the various guides but always tells me device unknown. I have done several times the installation of the drives but nothing. I read that it could be the cable, but sending it to take in China would take too much time (60 days to arrive in Italy) and on Amazon costs almost 16 euros. at this point I thought to build it myself. does anyone have the scheme?
May 17, 2018 19:03:01 GMT 1 ivan979 said:
he has ePacket service which is really fast and not expensive, i've used this method and it quite fast less than 2 weeks arrival.
www.aliexpress.com/item/FORNORM-Magnetic-pin-Charging-Cable-USB-2-0-Male-to-4-Pin-Pogo-Charger-Cable-Cord/32864458352.html?spm=2114.search0104.3.2.349b2d94OWRQTG&ws_ab_test=searchweb0_0,searchweb201602_2_10152_5722917_10151_10065_10344_10068_10342_5722817_10343_10340_10341_5722617_10696_10084_10083_10618_10307_5722717_10059_5711217_308_100031_10103_5722517_10624_10623_10622_10621_10620_5711317,searchweb201603_25,ppcSwitch_4&algo_expid=a4e0fa0c-9f6c-4727-a7ae-f3c466551b37-0&algo_pvid=a4e0fa0c-9f6c-4727-a7ae-f3c466551b37&priceBeautifyAB=0
I followed your advice I sent him to take … but given impatience I even built the cable … it will not be beautiful but it works …
excuse me but what is the latest firmware for the thor … I have installed Z10-KY-V10-20170628 but I seem to have read that there is the v11?
May 21, 2018 18:43:04 GMT 1 ivan979 said:
excuse me but what is the latest firmware for the thor ... I have installed Z10-KY-V10-20170628 but I seem to have read that there is the v11?
have you checked via OTA? most new updates will be posted on the firmware section.
I’ll check for a newer version but if you have flashed the BT calling firmware you may not have OTA.
I don’t know if Zeblaze officially supports it…
