I am new user of D5+ smartwatch and I have starnge issue with battery drain after start of the watch.
When I turn it on, after 30-40 minutes I lost 25-30% of battery. Even if I will disable all connections, I don’t use it all, battery just lost its % very quick. From 65-67% its starting to drop down normally. Watch works from 7 am to 10 pm, only with BT and pedometr on.
I have SIM in it, but with Airplane mode On, and Google account, but GPS is off.
Is it normal? Maybe only battery indicator is broken.
Do you have any idea how to fix it?
Thanks for your help.
Regards,
//EDIT 3:30 PM and only 30% battery left Only BT and pedometr on, and few notifications about sms and calls with vibration
I own a X5+ and experienced also a really bad battery life within the first few charging cycles. However I can confirm it is getting better from charge to charge, the watch fully powered off during charge.
In the meanwhile my watch sits idle in battery safe mode (deep sleep) for 4 days and 7 hours and still has 7% power left.
Some members wrote that it might be the indexing processes of android in the background after an firmware update that cause the drain. I dont know, but I remember the same behaviour from my early cell phone days with Nokia. Those phones reached their full capacity potential as well after a few cycles of charging.
I made factory reset. I dont have SIM card, I dont have google accout on the SW and only BT and pedometr on like I had before. It works much better, from 11 am till now i lost only 7% of battery.
I installed CPU Spy and Gsam Battery Monitor to monitor battery and cpu status.
