New Prime 2 Problem help please
My new Prime 2 has somehow locked into strange behavior when powering on. The watchface I selected briefly appears then goes into a screen with only current digital time, date, battery %, and a gear symbol but no response to swipes or taps. Only when taping the gear symbol do I get a new screen with “Turn on flight mode” check box that I do not select but select “cancel”. When I hold down the power button it comes up with the screen to power off, reboot,power save and screen shape selections. How do I get this functioning correctly again?
It sounds like you are in the ‘Power Save’ mode. Hold down the power button for a second or so until you see ‘Power save’ which will be somewhat grayed out and tap that icon - it will bring you back to regular mode.
Yes that was the problem now fixed thanks to your great advice!
