NEW KW88 FIRMWARE 20161215 - FIX POWER DRAIN…
Available here: http://roundandroidwatches.proboards.com/thread/18/kw88-firmware?page=1&scrollTo=2529
This firmware was given to us to test and supply by one of our sponsor manufacturers KingWear - for the KW88.
The description is minor bugfixes and in particular a power consumption issue has been identified and fixed.
As usual - don’t flash the pre-loader !!
Thanks! Didn’t really notice a power drain in the November build but if this is suppose to be better power management, then hell yeah. It’s a stable build yes?
Can’t test it I can’t yet connect my usb to computer aff… Hope the OTA gets here fast since I’m having powerful drains
Can’t be updated by OTA?
Somebody know if this version works well with date and day at custom clock faces?
does anyone knows where I can get procedures of flash firmware to kw88(step by step)l have google for days,but not sure how to do.
or the articles explain how to use sp flash tool(step by step please)
+Eddie Li
google how to use sp flash tool. Download the latest firmware, extract it, look for the txt file to input into the spflash tool and click download. Power off your watch and plug it into your pc and it should start flashing.
The tools and guides are all over on the tech support forum with the firmware
I’m having a bug in bluetooth to connect to sinwear
@Lucas_Diniz try to off/on your Bluetooth on your watch and phone if necessary. If still can’t connect, try rebooting your watch and phone if necessary as well…
Hi after updating the watch to this version my battery life was extended and now it’s hold on for 7-8 hour (from 100% to 15%).
However i have a problem with the notice vibrate. Every 3-5 days it’s stop working and only reset equipment helps.
Any ideas?
Thank you
Asaf.
Say my brother Pablo Eleven (Pablo11), we can convert the rom of a smartwatch into android wear ??? thank you for the answer !
@Djallel_Benmdjahed that would be a no.
@Djallel_Benmdjahed
thanks Zebri - no, absolutely not
Does a tutorial video how to install firmware
Yes - in the same area where you get the firmware. Just have a look around and read it very carefully !!! Use download only mode in SP Tools and do NOT flash the pre-loader…
Do not flash the pre loader??? lol
Can’t figure what to do.
I just updated my watch with 20161104 for the first time.
Maybe read the instructions over on the other forum?
thanks Pablo Eleven (Pablo11)
@Asaf_Tal
this is a question for the technical forums here: Round Android Smartwatches
This community is for general chat and faces
