I’ve a big problem started after the update to this new firmware. Now my smartwatch doesn’t connect to my Network Operator (TIM, Italy). The SIM works correctly and I see full signal, but it doesn’t works. In the Settings, If I try to connect manually I see my network operator in the list, but clicking on it this message appear: “Can’t connect to this network right now try again later”.
I tried to reflash the original firmware linked by Pablo11, but still no connection. I don’t know what to do… before the upgrade my SIM worked well.
Can someone help me?
lemfoles1 please go into your phone dialer and dial *#06# and report the IMEI you see there (if any) please sanitize some numbers by replacing them with a letter like 3569XXXX5643809.
So, your question saved me. I understand the problem was the IMEI that was deleted during the update of the firmware.
I solved with this guide, now the SIM card is working well:
From that I understand from some of the flashing video in youtube, we are suppose to uncheck the preloader checkbox before flashing to retain the IMEI in the watch.
According the video I posted yes, you have to uncheck the first voice (preloader). But fortunately restore the IMEI is quite simple following the guide
May 25, 2017 19:28:12 GMT 1bengo said: I) It's a destructive reinstall, so all was it LES1 will be deleted. If you do not want that search for alternative methods or wait for the OTA update, when available. Or at least backup user data and apps.
I wrote a wrong statement: I just noticed that in my case data was not lost, so installation is not destructive! That's better, in any case a backup is always a good attitude.
After extracting the files and following the instruction, I connected Watch with 4pin connector through USB but nothing is updated on the phone or software. Any help?
Hi I bought the lemf, but without sim card does not have phone function via bluetooth ie does not replace the phone for incoming and outgoing calls …? The wiiwear app is completely useless?
