NEW and a little lost...can you help me?
Hi, i have received my kw88 the last week.It has an android version 5.1. I have read posts but I m not able to know easily what can I do to install new faces, because i dont like any it has from factory.I have to install a launcher? But, What launcher may I to install?
After install a launcher, what must I do?
Sorry, perhaps my question is easy to find the answer, but I m a little lost.
Thank you in advance.
You should start here: /thread/758/universal-launcher-new-generation-2
Download that launcher and install it on your watch. Once you do that, make a folder called Clockskin in the root folder of the watch. Once you’ve done that put watch faces you want on that folder on your watch.
Thanks…
Please help me. I have the Lemfo Les 1 and i do not know where this app called launcher is. i install something called apk but i did not know how to use it so i uninstalled it. besides its so many in google play that it made me confused. Can someone please help.
you do'nt need to install apk for Watch faces. 1. create on your pc a folder that is called Clockskin. 2. download the watchfaces that you want ONLY folders which contain png and not more folder. extract the zip file and transfer these folders to the Clockskin folder. 3. copy the Clockskin folder to your watch and turn off and on your watch and you'll see the watchfaces that you added.  ***remember any change you do to the folder you need the watch to be on stock watchface.
Alternatively, you can read this guide and follow it's recommendations. Basically it's very simple - install apk and download watch faces.
Good evening to everybody.
Have a trouble with an original watch faces at kw99 : chosen watchface suddenly was replaced to a first watchface in a row.
And now instead of a chosen watch face and nearest to it, kw99 shows a recent app and then a first watchface again.
Reboot didn’t solve an issue.
Just two of watchfaces don’t want to choose, another ok.
Please help and advise where can I find a solution?
P.S. Factory reset solves an issue.
P.S.S. Next day issue appears again.
P.S.S.S. Friends told me that watchfaces with temperature indication don’t work when temperature is below 0 Degrees.
Can’t show a minus symbol.
That’s right, I have a problem with only two watchfaces which have a temperature indication.
