Need Help with my Lem 10
I have a Lem 10 watch that I bought new several years ago but just started using it. It is running Android 7.
I loaded all the same files that I was running on my previous Lem 10 and everything worked ok. I installed and was using Smart Touch Pro and Display Brightness apps. The worked ok, no problems. About a week ago they stopped displaying on the screen. I had both Battery Optimzation and Display over other apps turned on. After the problem started I checked and they were still active.
I did a factory reset and then reloaded and set up both those apps but the problem still exists. Anyone know what else could be causing this issue.
Could the apps have updated so they no longer work on a old firmware ?
No because I uploaded the apps from my files and not the play store. They are the same apps that I used previously
