Jan 9, 2018 21:50:08 GMT 1RASC Moderators said: Sounds like a pairing issue to me. And possibly using many different devices on Bluetooth.
Start from scratch - make sure no old BT relationship is on the watch and phone.
Then start the pairing process using the WiiWatch application on the phone. Not through settings.
Already done, it works with WiiWear but not with WiiWatch. Anyway when a call / sms is coming, my Les1 does not vibrate! Why? The app does not support vibration?
it should, on my wk99 vibration and sound work fine. i use wiiwatch.
Jan 9, 2018 23:52:45 GMT 1pycon said: Already done, it works with WiiWear but not with WiiWatch. Anyway when a call / sms is coming, my Les1 does not vibrate! Why? The app does not support vibration?
I don’t know why but I’m been able to connect with WiiWatch too. But as with WiiWear, when a new call / sms is coming, my LES1 does not vibrate
my les 1 soft z10-yfz_hfp-20171122 all the time disconnect with Watch Droid and don’t want to connect with wiiwatch at all.
Soft rooted.
Watch vibrate and ringing
my watch all the time disconnect ( Bluetooth switch on and off) in the watch and i don’t know why.
phone brand Sony Z1 android 5.1.1
I have exactly the same situation with LES1, FW Z10-YFZ_HFP-BT-20171122 AND Z10-YFZ-V10-20171011 (I upgraded to the latest and then went back for despair).
I have two BT addresses, the connection is NOT stable with BT that comes and goes.
I tried Watch droid, WiiWatch with same issues of connection and disconnection.
There has been a short period of reliable working after I fully erased the Watch (Factory restore) and Flashed the Upgrade FW with FlashTools \SP_Flash_Tool_v5.16.36. It lasted for three days and then it started again.
My phone is a OnePlus 5T, but I had same issues with OnePlus ONE with LineageOS.
I also own a XiaoMi Mi Fit2 that works perfectly and never misses a notification. Obviousply I tested with the BT list of paired devices CLEAN on the phone without success.
Jan 8, 2018 10:59:28 GMT 1pycon said: I'm on 22.11.2017, latest BT Firmware, but after a few weeks with other smartwatches I've started to use LES1 again.
Surprise… 1 month ago I forgot to test the notifications. No problem, I install the app and :
M2D Sender & Reveiver no longer work, the Select Device & Connect buttons on the M2D BT Manager ( installed on my smartphones ) don’t connect anything
WiiWatch Assistant installed on my smartphones seems to find nothing, no BT devices, always an empty list
Watch Droid Phone & Assistant are the only apps that work but the watch doesn’t vibrate receiving a call and the connection falls every 2 minutes
Jan 12, 2018 12:46:03 GMT 1raduch85 said: my les 1 soft z10-yfz_hfp-20171122 all the time disconnect with Watch Droid and don't want to connect with wiiwatch at all.
Soft rooted.
my watch all the time disconnect ( Bluetooth switch on and off) in the watch and i don't know why.
Soft rooted.
Can u tell me which firmware has the best battery backup
Is Z10-KY-V10-20170628 or Z10-KY HFP-BT-20171122 or z10-ky-v04-20170327 or z10-ky-v11-20171011 . Please tell me that which firmware has the best battery backuo. I m currently on z10-ky-v11-20171011 Zeblaze thor please
Feb 5, 2018 15:51:01 GMT 1rob27 said: Just the same for me wiiwatch doesn't find anything and watch droid disconnects. I was wondering what android is your phone? Mine is 8 (oreo)
I returned back to July 2017 firmware in order to obtain a stable BT connection.
Hi... I also have a lot of problems with Bluetooth. Is July 2017 the best? I´d like to use Watch Droid without having the watch vibrating every 15 seconds...
I answer myself... whole day using Watch Droid with July 2017 firmware, 0 problems
Feb 20, 2018 19:41:31 GMT 1cesarm said: Hi... I also have a lot of problems with Bluetooth. Is July 2017 the best? I´d like to use Watch Droid without having the watch vibrating every 15 seconds...
Exactly. But if you try to run Wireless Update and update to Patch 2018.02.06, after this flashing BT disconnections will begin again
Hola q tal soy nuevo en esto. Acabo de comprar el les1 y lo actualice con el nuevo firmware Z10-YFZ-V11. Pero no me puedo conectar ni x Bluetooth ni x el código QR. Alguien me puede ayudar? Se los agradecería bastante.
Mar 3, 2018 2:39:18 GMT 1moreno said: Hola q tal soy nuevo en esto. Acabo de comprar el les1 y lo actualice con el nuevo firmware Z10-YFZ-V11. Pero no me puedo conectar ni x Bluetooth ni x el código QR. Alguien me puede ayudar? Se los agradecería bastante.
