My No.1 D5 has some problem. I noted that is the second time the smartwatch was stuck at initial logo after I turned it on after 2 or more days in off state. The first time I had to flash rom. I did not do anything wrong to mess up with rom.
From the flashing I’ve done, unless you have SPTools format, it seems like there is lingering problems. I’ve had better luck have it format and then download the latest firmware. That would be my recommendation.
I have to flash ROM again but first, sp tools gave an error (PMT changed for the ROM) and I chose “update firmware”. It worked (and it was formatted).
So, all good now?
Yes. But this situation intrigues me.
