my KW88 won’t turning on or charging please help :(
Hi… i need help for my kw88 … i used it only for six days since i bought it online. but last night i put on charge overnight. when i wake up the watch cannot be turn on and after i search how to recover it. i found that disconnecting the battery cable will help the watch back to normal. yes i did it and the watch turning on but just only for 1hr and after the watch switch off again and cannot turn on again. i tried several times for disconnecting and connecting the battery the watch still turning on. but now never turning on nor charging … i try to flash in another firmware and its successful but the watch still off. i dont know if its already dead. when connecting to the computer (windows 10) its took 10 second before i heard the sound that the watch are connected and after 3 seconds the watch disconnected again and again. im so frustrated i need my watch back to life. i hope someone would help me out :sob:.
Oct 23, 2017 3:20:07 GMT 1 elmuller2016 said:
Hi.. i need help for my kw88 .. i used it only for six days since i bought it online. but last night i put on charge overnight. when i wake up the watch cannot be turn on and after i search how to recover it. i found that disconnecting the battery cable will help the watch back to normal. yes i did it and the watch turning on but just only for 1hr and after the watch switch off again and cannot turn on again. i tried several times for disconnecting and connecting the battery the watch still turning on. but now never turning on nor charging .. i try to flash in another firmware and its successful but the watch still off. i dont know if its already dead. when connecting to the computer (windows 10) its took 10 second before i heard the sound that the watch are connected and after 3 seconds the watch disconnected again and again. im so frustrated i need my watch back to life. i hope someone would help me out 😭.
the only thing you should do is contact your seller and ask for new watch or refund it sounds like hardware problem and not software so it is better that you do'nt change anything or do anything with it .
thanks but my watch is charging now. i open the watch unplag all the cables and replug still nothing. its make me so stressed and very annoying. in my mind i dont have nothing to do with it. and makes me pissed off. :imp: i dont know what things came on my mind because im so desperate to it. and i started fillip or flicking off the motherboard of the watch for many times. :scream::japanese_ogre::smiling_imp: and guest what the watch started charging :grin::grin:it started from 1 percent and now its 61 percent in 30 mins :blush::blush: im so happy that my watch is not dead
