Metro PCS support? (KW88)
Does this watch support METRO PCS? I cannot figure it out.
What is metro PCS ?
Search in the forum for more information.. metropcs is using t-mobile network. So the frequency is band2, band4 or band12. With the kw88, you should only find useful the band2 but with a weak connection on gsm (2G)..
Jan 7, 2018 15:41:32 GMT 1 ricktop said:
metro pcs is a "virtual" service provider pcs is a type of communication "protocol" on the 1900Mhz for instance ..
metro pcs is a “virtual” service provider
pcs is a type of communication “protocol” on the 1900Mhz for instance …
When picking a network from available networks I get the error "Can't connect to this network right now"
I use SpeedTalk Sim Cards which also work off of T-Mobile network. I can either manually load the APN settings for SpeedTalk or just let the watch load T-Mobile network and either way it works. So I suggest if Metro PCS runs off of T-Mobile network try connecting through T-Mobile.
If you put a metropcs sim card in your kw88, you should:  - only be able to connect a "2G T-mobile" network  - get closer to T-mobile cell tower for better connection (  - check your settings: -air plane off- valid imei- etc. hope this helps ..
