M2D Apps - Sender, Bluetooth Manager - Receiver
I am in need of some assistance please.
I have a finow x3+ paired to a s7 edge, and I don’t see an option to respond to sms through Bluetooth. What am I missing?
Dec 24, 2016 22:43:56 GMT 1 zer00x said:
I am in need of some assistance please. I have a finow x3+ paired to a s7 edge, and I don't see an option to respond to sms through Bluetooth. What am I missing?
for now it is not possible i found this but not sure how great it is because no notification appear when an income sms or call comes in.
/thread/393/sms-calls-watch
I found an app that seems top work well for this, but it only works over Wi-Fi.
It’s called join.
I think that one of the main issues to be solved is the contact picture appearing on a receiving SMS. On mine it appears in messenger, calls and Whatsapp but not on SMS.
I am new in this board and first of all i want to say hello to all of you :slight_smile:
I’ve tried this app('s) but have some trouble:
  1. I’ve installed playstore versions of BT Manager and sender/receiver app
  2. It works 15 min then it doesnt forward notifications. Some times it works again but some times i have notifications just on my phone :frowning:
    If i tab the test button i only get the notification on my phone. Manually reconnecting solves this issue for a while…
  3. It reconnects very often and the vibration during reconnect is really exhausting after a while…
  4. I have either one notification of the sender an the bt manager on my phone (“tap to open”)
    If i try to avoid this to be displayed, it doesnt forward notifications. Is there a way to make the notification invisible?
So perhaps some of you can give me a hand with my problems.
Thank you in advance!
Ben
Hi can some one help please these are develper notes
If you’re using these Apps with a smartwatch as a receiver with 3G, be sure you read this:
Install the app Gesture search.
Find Data Usage.
Search for Google Play Services.
There you uncheck the Button for mobile usage in background or something else
My question is is he reffering to google gesture search app if yes do i install on my watch (Kw88)
Jan 4, 2017 20:33:50 GMT 1 jackster said:
Hi can some one help please these are develper notes If you're using these Apps with a smartwatch as a receiver with 3G, be sure you read this:
Find Data Usage.
yes, he means this one:  play.google.com/store/apps/details?id=com.google.android.apps.gesturesearch&hl=en
Hi sonia
ok but do i install on the sender and not on the reciever or both as i can only access data services on my sender?
Jan 4, 2017 22:05:14 GMT 1 jackster said:
Hi sonia ok but do i install on the sender and not on the reciever or both as i can only access data services on my sender?
no, on your watch, true it took me a while to access it on the watch.
Give us a clue then sonia how did u do it on your watch lol
i've deleted the app so i'll install it and try to make a video about it do'nt forget it took me time to do it, do'nt know why was'nt easy to find data usage. anyhow still not working with 3g tried or maybe i did'nt do something right. will also check that again but you gave me an idea maybe to check aslo on my phone.
cheers sonia as the only thing i can find in watch settings is restrict app background?
hi…
we need to install M2D Sender on phone ? and M2D Receiver on our smartwatch ?
thank you.
Jan 5, 2017 3:29:36 GMT 1 arilz said:
hi... we need to install M2D Sender on phone ? and M2D Receiver on our smartwatch ? thank you.
M2D Bluetooth Manager on both, Phone and Watches M2D Sender on Phone M2D Receiver on Watches
i see…thank you very much
let me check and reply as soon as i  can.
I have some newbie questions I’m afraid.
  1. I’ve had a few issues with M2D stability (using M2D Bluetooth Manager, Sender on phone, Receiver on smartwatch, Finow X5+ and Xiaomi Mi 5S) - when installed yesterday, I got notifications for everything except calls. However, on uninstalling and reinstalling I now have notifications for everything, but don’t really know why! I also seem to sometimes have issues with the sender thinking it no longer has permissions to get notifications - even though it does. I then deselect and reselect the notification permission granting and it seems fine. Are there any things to look out for?
  2. Now it is working, I’m getting fussy - it works great, but I’d like to reformat the output on the smartwatch. I’ve changed the text size which helps, but would really like to hand the messages off to something like Heads-Up Notifications to apply more in the way of formatting. Is this possible? I’ve tried but not managed - must be missing something.
  3. And finally a really silly question - is M2D more stable through a bluetooth or wifi connection? And would smartwatch battery life be reasonable using wifi only instead of bluetooth only? I’ve come from having a Pebble - so shiny colour screen is lovely, but a battery life of ~24 hours is a nasty shock!
Thanks very much,
Phil
Last days i has been problems with recieve notifications trouhg 3g. Somebody did have this problem?
what is your watch brand?
I have a Finow Q3.
