Nov 1, 2016 17:59:04 GMT 1 alfonsosen said:
does in power saving turning off screen is marked? if so unmark it, if you still having problems, try to reset the bt m2d app and pair the devices again and see if it fixes the problem.
There are an app like M2D?
M2d it s fantastic but not works after dhort time
Nov 1, 2016 20:38:54 GMT 1 alfonsosen said:
are you using the m2d bt manager? did you make sure that in power saving it is’nt marked the option to turn off connectivities when the screen is off?
I have a problem with the watch that is losing the bluetooth connection and I have to pair again. I don’t know how to fix this.
Maybe is the same problem like yours?
Nov 2, 2016 18:26:19 GMT 1 alfonsosen said:
Yes using m2d bt manager, not in power saving mode. Where are the option of connectivities??
Nov 2, 2016 19:04:09 GMT 1 pacosal said:
Hi,I have a problem with the watch that is losing the bluetooth connection and I have to pair again. I don’t know how to fix this.
i had unpair many times but now i do’nt i have the x3+ and i had 2 updates and after that i reset the watch and now i do’nt have the unpair anymore, on the phone i have a problem with the bt manager app it keeps want to close.
If you have problems with bt manager, enable debug and once it fails, send me the file called m2d_***.txt in order to check it
Nov 3, 2016 9:05:20 GMT 1 pacosal said:Nov 2, 2016 21:45:41 GMT 1 soniasophie9697 said:
Thanks for your answer. I will reset the watch.If you have problems with bt manager, enable debug and once it fails, send me the file called m2d_***.txt in order to check it
will do:)
Nov 3, 2016 15:02:32 GMT 1 alfonsosen said:
i do’nt understand what do you mean? you do’nt get notifications only if you enter the app?
Nov 4, 2016 15:47:59 GMT 1 alfonsosen said:
Just connect the two divice notifications work after some time notifications do not come anymore, and resume only after you have sent the test message with the application sender notifications are riinviate to the second device
ok, i think it got to do more with the phone than the watch, try to reset the app and start again, do you use m2d bt?
Hello everyone!
It’s amazing the great development of M2D, congratulations Pacosal you’re a genius programmer !!!
The only observation that could leave, is a failure to receive notification of incoming or missed call, does not work after the last update M2D Receiver, I use a D5 +
If you can consider for the next update would be great!
Thank you.
Hey guys! I have HUGE problem,.I have a finow x3 plus ,everything works fine with the m2d,but when someone is calling, I have a call notification wich appears every 0,5 seconds continously and I can’t end it until I turn off the screen. and 2 sec later it starts again… any help? Thanks a lot!
I will check last issues soon.
New versions released!
- Bugs Fixed
