M2D Apps - Sender, Bluetooth Manager - Receiver
M2D appearing on lock screen
Hi
I have Finow X5 and Samsung Galaxy s6 edge. I used M2D apps for sending/receiving notifications.
I have two questions:
  1. The M2D app continuously appear on the lock screen of the phone. Is there a way to hide it?
  2. Is there a way to receive notifications on the watch for an app in its original form? (e.g. whatsapp msg should appear as whatsapp msg on watch notification, rather than as an M2D receiver notification).
Thanks Pacosal. M2D is a great app to have. Keep the good work going.
I’m waiting for the arrival of my KW88 and I would like to know whether to have communication with the telephone must install the application “Sinwear” or better “M2D”.
Or both.
En español:
Estoy esperando la llegada de mi KW88 y me gustaria saber si para tener comunicacion con el telefono debo instalar la aplicacion “Sinwear” o mejor “M2D”?
O ambas?.
Gracias Pacosal.
Oct 23, 2016 21:37:34 GMT 1 bokexperiano said:
if sinwear is like Watch Helper then M2D is way better because it allows you to reply to many apps.
Then just install M2D?
in my opinion yes, if you install the m2d sender and m2d bt on the phone and m2d reciever and m2d on your watch you’ll be able to reply to apps.
please, any of you could make a video in order to set it at play store? I hate that part. If you upload the video to youtube, better.
I prefer developing than make videos.
Oct 25, 2016 17:43:28 GMT 1 pacosal said:
We really need someone like smartwatchticks to help with video.
I don't really have the correct setup for this.... I will make sure he knows you need a little help here.
New versions M2D Sender and Receiver
  • New Music function added (long press any screen) - Google Play and Spotify
  • Only Smartwatch with Bluetooth connection
Enjoy
The app works great!! but it drains the battery fast (using bluetooth).
Pacosal if you can improve the battery usage it will be a perfect app !
Oct 27, 2016 16:46:48 GMT 1 pacosal said:
New versions M2D Sender and Receiver - New Music function added (long press any screen) - Google Play and Spotify - Only Smartwatch with Bluetooth connection
Enjoy
I love your app!!
Can you get back the notifications for the SmartWatch mode?
Another thing, can you make it that when you long press on the “trash” icon it will ask you to clear all the messages?
Thanks!
I would like to make a video
I am hoping to do an app review of M2D on the SmartWatchTicks channel, and you could use it on your Play Store if you want. It will be quite awhile before I can get to it though. First of all, it takes quite a bit of time to set up as you need three devices -- a sending phone, a receiving phone, and a watch -- all to make it happen for a demo. I also have no experience with the app yet so there is a learning curve to overcome. Lastly, since my main focus is watch reviews, I'm going to have to give priority to all the new watches coming out now before the holidays, as well as the monthly summaries of custom watch faces developers have released (I'm already having to combine September and October in one video, just to keep up).
If any of you are motivated to help pacosal with a video, that would be great. Id love to watch it as well so I can learn about the app for a full review video later.
Enjoy
I love your app!!
Thanks!
I don’t understand your comment about notifications!
The trash option is a good idea, by the way.
Hi
I also found the notifications on the lock screen annoying. I have a Samsung Note Edge.I went into applications, M2D sender app, notifications and select turn of on lock screen, do the same for the bluetooth app.
Everything OK now.
Hi
Everything OK now.
Update:
When I blocked the notifications from lock screen I noticed Bluetooth error message. Kept disconnecting and not auto connecting.
I have now kept notifications on lockscreen and no more disconnection problems.
I have one minor problem. When I try to open the receiver app, I get a black screen.
Other than that. I am receiving emails, whatsapp messages and able to reply to them.
I love your app!! Can you get back the notifications for the SmartWatch mode? Another thing, can you make it that when you long press on the "trash" icon it will ask you to clear all the messages? Thanks! I would like to make a video
I don't understand your comment about notifications!
When I am on “smaertwatch mode” I dont get any notification,The app just open on the message. I domt get the notification so I cant use the “heads up notification” app anymore.
Oct 28, 2016 10:25:10 GMT 1 lacmac said:
you do'nt see the inside info of the app? you do'nt see the notificatins on it? if so, try to update it and if it is up to date try to uninstall and reinstall.
you do’nt see the inside info of the app? you do’nt see the notificatins on it? if so, try to update it and if it is up to date try to uninstall and reinstall.
I dont get the notification to here:
postimg.org/image/qcg5iucgl/
I tried to reinstall everything.
Oct 29, 2016 9:43:56 GMT 1 idoaflalo said:
i use NiLS and i get notifications on the screen itself but if you do'nt have this kind of app you should get notifictions on the notifications page. i've noticed that the android notifications of the system cause problems and need to be disabled.
Smartwatch NO. 1 D5+ and phone Huawei P9 Plus, the idea of app it’s fantastic but it works for a short time then to get back the notifications have to postpone the test message, how do I fix?
Nov 1, 2016 17:59:04 GMT 1 alfonsosen said:
Smartwatch NO. 1 D5+ and phone Huawei P9 Plus, the idea of app it's fantastic but it works for a short time then to get back the notifications have to postpone the test message, how do I fix?
I have the same problem, when some time passes notifications stop and take the app bluettoth get worse
yo tengo el mismo problema, cuando pasa algun tiempo las notificaciones dejan de llevar y con la app de bluettoth llegan peor aun
