is a very good application, works well with wifi, 3g and BT, only lacks the functions of call, that if I remember correctly the application droid watch has that. It’s excellent anyway.
Nov 8, 2017 7:07:38 GMT 1 sakifx9 said:
My watch doesn't fill the app to the screen
use the tablet version not the watch version i also had problems with the watch version. reset the app with Settings Search and start over.
***if you can access settings on the app that is better and just change interface.
Any way of not getting the caller id picture when receiving a phone call?
My watch doesn’t fill the app to the screen
use the tablet version not the watch version i also had problems with the watch version. reset the app with Settings Search and start over.***if you can access settings on the app that is better and just change interface.
I am using M2D receiver on the KingWear KW88. I tried to choose the tablet option but it doesn’t display properly at all-only a sliver at the top of the screen with no function. So, using the smartwatch option which mostly works although some notifications don’t appear (typically Gmail for me, not all, just sometimes) and with the round screen it isn’t possible to access the bottom option/s in settings. Not possible to adjust the display - no option for oblong display listed…
Feb 5, 2018 10:39:58 GMT 1 lancelink said:
I am using M2D receiver on the KingWear KW88. I tried to choose the tablet option but it doesn't display properly at all-only a sliver at the top of the screen with no function. So, using the smartwatch option which mostly works although some notifications don't appear (typically Gmail for me, not all, just sometimes) and with the round screen it isn't possible to access the bottom option/s in settings. Not possible to adjust the display - no option for oblong display listed..
maybe it is time guys that you ask the developer on his channel cos he is'nt answering posts here and i can't help much, i will check with my kw99 the app but i know that the smartwatch version does'nt work well on our watches.
too bad its not for IOS
do you have sim inside?
no…
if you had you could have used a notifications app that uses wifi or 3g as pushbullet or pplconnect. have you tried wiiwear?
Mar 26, 2018 16:01:16 GMT 1 soniasophie9697 said:sbcobra
Wiiwear app cant find the watch…
Mar 29, 2018 18:35:15 GMT 1 sbcobra said:Mar 26, 2018 16:01:16 GMT 1 soniasophie9697 said:sbcobra
sorry, i do'nt think there is too much for ios. try to notify wiiwatch developers about your issue and they might fix it with updates for ios.
Did anyone try m2d with the new Prime watch ?
Should we use watch or tablet version for that ?
If I want to be 3G connected when away from my phone’s, is there any need for using the Bluetooth connector when in reach of phone, or simply use 3G/WiFi always ?
