M2D Apps - Sender, Bluetooth Manager - Receiver
Apr 28, 2017 20:08:09 GMT 1 hari said:
Hi all
I try to set up these M2D apps and I can’t get income calls message and who is calling on my smart watch when I get it, and I wonder if these apps send only message no incoming calls
or it is a setup problem. I get vibrations for incoming Gmail whatsup not from incoming calls.
Thx
uninstall and reinstall the apps and see if they work, you should get notifications for the incoming calls also.
Thanks for your answer I did like 3 times the uninstall and install no change.
Is any member that have the Finow 5x plus connected to an android unit running the last android 7 with a Bluetooth connection? and the apps working correctly.
I will appreciate any help.
Thx
Hari
Apr 20, 2017 19:16:37 GMT 1 soniasophie9697 said:
Apr 20, 2017 9:57:10 GMT 1 dverbame said:
thanks for answer.
is there any app that cover all apps ?
and about your question, i mean : i can recive my phone messages on watch… but it don’t work for my telegram app .
for now the only app you can use to reply is m2d and also i use My SMS for calls and sms, but there is also the Swapp Link but again you can't reply with it only get notifcations, btw in M2D you can set it as tablet and see the full notifications you get and telegram you should also get, check settings on the app that on the phone.
Please a link for swapplink ?
for now the only app you can use to reply is m2d and also i use My SMS for calls and sms, but there is also the Swapp Link but again you can’t reply with it only get notifcations, btw in M2D you can set it as tablet and see the full notifications you get and telegram you should also get, check settings on the app that on the phone.
apkpure.com/swapp-link/com.preiss.swapps.link
**the developer of this app has stopped working on it but still good.
Thanks, i will try. Is Bluetooth stable ?
with the D5\D5+\X3+ yes but with the s99a horrible.
I have X5 (not X5 Plus)
the x5 is simillar to D5 and it worked great with it, no BT problems.
I really like the m2d App. However I haven’t been able to get the media remote to work. as I keep pressing on the screen of m2d receiver, nothing happens. any suggestions? I am connected via BT, and have a Lemfo LEM5
Hello, I have Lemfo LF16. I put M2D on the phone and watch. At first there was an opportunity to respond to messages and output photo contacts (WIFI). Then he tried the bluetooth, the photo was removed and the opportunity to reply to the messages was lost. Some messages are duplicated several times! Reinstalled the application on the phone and the clock did not help. What could be the problem?
the developer is aware of these issues with 5.1 watches and is doing his best to solve it, so soon this will be fixed and all be notify here on the thread:)
the developer is aware about the issues with 5.1 watches and is working to solve these problems.
Thanks for the quick response!
Hello,
I am doing something wrong, or this app works the same as Watch Helper in D5+?
Regards,
MK
May 17, 2017 13:56:36 GMT 1 lasica said:
Hello,
Regards,
MK
what do you mean? i do’nt use watch helper because it is just horrible app, m2d is way better the developer is aware about the problems with 5.1 watches and he is working to fix the problems it is also got to do with android 7 that most phones got.
Hello soniasophie9697,
Thanks for your answer. I mean that I can’t answer call, or replay to sms, and I only get notifications the same as with Watch Helper. They look exactly the same
with Watch Helper you only get notifications but with M2D there are apps which you can reply like Whatsapp.
I dont use Whatsapp. I can't replay to SMS, I can't manage calls. Apps works really bad with SGS7, often is stopped, and conecction with sw is lost.
I dont use Whatsapp. I can’t replay to SMS, I can’t manage calls. Apps works really bad with SGS7, often is stopped, and conecction with sw is lost.
these are standalone watches you can only get notifications, i have samsung note 5 and for me m2d works fine only just after the update to android 7 started to have problems and the developer is aware and working on it. m2d is the ONLY app which allows you to reply to some apps there is also My SMS which allows you to reply to sms and calls (you can only call back from your watch no bt calls).
Yes I know that, and It is very sad. This SW(D5+) is very powerfull but its software and optimalization is comleatly dissaster.
Only what I need is to get notifications from Phone, answer to SMS, and manage calls (answer/drop call). No more. So easy but, but so hard.
