I’m going to ask a favor. Someone with a lem5 can take a close-up with the cap removed to put the sim, I let loose a part of the bracelet and I broke the connector of the data antenna. And I would like to know if I can re-weld it. Thank you
If its the connector on the board you may be able to solder it, but if its the wire, the connector is not soldered on to it.
