If someone have some skill in 3D printing, know someone or company in 3D print or have some ideas to make look better the lugs of the watch,because i want to change from spring bars to screw tub rod,i did use my dremel and mess up the watch,i know i can fix it with some welding epoxy plastic compound but i want to do something different.
the watch i am going to paint it too. the screw tub rod is 33mm and the separation of the lugs is 27.5mm
I can see them here at work. For some reason it was asking me to get permission when viewing on my phone. Were you trying to drill out the holes to be bigger for the screw tube? 3d printing might be an option, but what are you planning on printing? I’m wondering if you couldn’t email Lemfo and see if you can just buy the bottom part of the case.
There is no “bottom part of the case” the whole body is one piece.
The only separate piece is the sim cover.
So you would have to print the whole watch body.
Of course, the other problem is that if you try to remove the screen assembly from the watch it will definitely end badly.
I have done this and my screen is now covered in black lines and bleeds light in from the back lights - unusable.
So be very careful what you decide to do.
Thanks Pablo11 I think I got an idea if you are willing to sell me your broken LemX I can cut the lugs from your and use glue and insert screws in both sides and done, so how much you want for your watch
Yikes, well I guess that answers some of my questions.
leafar: Do you think just gluing the lugs will be strong enough? I’m not sure what else to suggest as it seems Lemfo has made it difficult to fix.
Hahaha, you need to play the game(s) to appreciate it. You could make a smaller pip boy. When i get a smart watch I will probably put a pip boy clock face on it (for a while at least).
