New firmware LF-16 here goo.gl/2HjihL
The firmware differences were talked about before - my apologies for not updating all the threads - I have been extremely busy with personal life and sorting out these firmware issues.
Anyway - the bottom line is there are 2 versions for both the Domino and the Lemfo.
One is for the newer model screen which has HEHUI in the build number and one is for the older model screen and does not have HEHUI in the title.
To check which one you need go to settings - About Watch and check down the towards the end of the menu list and see which version you have.
If you have the HEHUI version it will be there in the Build number.
I hope this helps and my apologies for the delay in updating the threads.
Hi, I need the firmware for LF17. I try to load the one that you posted but it didn’t work, the watch just vibrate for a second then the display become grey and then goes off again!
Could you help?
I did the memory test with the flash tool and this is the result:
============ Memory Detection Report ===========
Internal RAM:
External RAM:
Type = DRAM
Size = 0x20000000 (512MB/4096Mb)
NAND Flash:
ERROR: NAND Flash was not detected!
EMMC:
EMMC_PART_BOOT1 Size = 0x0000000000400000(4MB)
EMMC_PART_BOOT2 Size = 0x0000000000400000(4MB)
EMMC_PART_RPMB Size = 0x0000000000400000(4MB)
EMMC_PART_GP1 Size = 0x0000000000000000(0MB)
EMMC_PART_GP2 Size = 0x0000000000000000(0MB)
EMMC_PART_GP3 Size = 0x0000000000000000(0MB)
EMMC_PART_GP4 Size = 0x0000000000000000(0MB)
EMMC_PART_USER Size = 0x00000001c3000000(7216MB)
UFS:
ERROR: UFS was not detected!
============ RAM Test ============
***Data Bus Test: ***
[D0]
[D1]
[D2]
[D3]
[D4]
[D5]
[D6]
[D7]
[D8]
[D9]
[D10]
[D11]
[D12]
[D13]
[D14]
[D15]
[D16]
[D17]
[D18]
[D19]
[D20]
[D21]
[D22]
[D23]
[D24]
[D25]
[D26]
[D27]
[D28]
[D29]
[D30]
[D31]
OK!!
Address Bus Test:
[A1]
[A2]
[A3]
[A4]
[A5]
[A6]
[A7]
[A8]
[A9]
[A10]
[A11]
[A12]
[A13]
[A14]
[A15]
[A16]
[A17]
[A18]
[A19]
[A20]
[A21]
[A22]
[A23]
[A24]
[A25]
[A26]
[A27]
[A28]
OK!!
RAM Pattern Test :
Writing …
*** 0x44332211, ***
*** 0xA5A5A5A5, ***
*** 0xA5A5A500, ***
*** 0xA500A500, ***
*** 0xA5000000, ***
*** 0x00000000, ***
*** 0xFFFF0000, ***
*** 0xFFFFFFFF, ***
OK!!
Increment/Decrement Test:
Writing…
OK!!
