Hi guys i have been new in this forum since i got my new lem8 and i wonder how do i replace the lem8 strap/band, anybody can help me please…thank you
Its non removable. I also fall for it.
but what happens if you remove it, is there any effect? is it part of the antenna system. i’m considering turning it into a pocket watch with a 3d printed custom cover and would love to remove the straps and grind down the supports.
anyone have any thoughts?
There are antennas inside upper strap for GSM/LTE the other i think ist for WiFi … Tryed to Change strap and begun with the upper…the GSM antenna ist now wery Bad after i broke the cabel… I want to try to build the antennas one day Intro the watch to Change the strap.
I bought the LEM8 strap now, so I will change it when I arrive.
Where did you buy the strap?
I bought a strap from Ali and it comes out when I find it. You can buy it at 22 millimeters.
Can you provide a link?
Does the watch still function as a bluetooth notifier without the factory straps?
In other words, do the straps also serve as BT antenna?
Mar 27, 2019 16:31:09 GMT 2 kramer5150 said:
Does the watch still function as a bluetooth notifier without the factory straps? In other words, do the straps also serve as BT antenna?
I’ll give you a test and let you know when the watch strap arrives.
Mar 22, 2019 2:27:15 GMT 2 filli said:
There are antennas inside upper strap for GSM/LTE the other i think ist for WiFi .... Tryed to Change strap and begun with the upper.....the GSM antenna ist now wery Bad after i broke the cabel... I want to try to build the antennas one day Intro the watch to Change the strap.
if i'm not mistaken you can actually buy new ones.
if i’m not mistaken you can actually buy new ones.
checking… tag me and few days to make sure to get updates.
Apr 3, 2019 11:35:44 GMT 2 freemari said:
나는 시계 줄을 샀다. .. 시계 줄을 바꾸는 방법 누가 LEMFO LEM8 모델을 알고 있는지 나에게 이야기해라.
Can anyone tell me how to replace the strap?
Apr 3, 2019 11:58:21 GMT 2 freemari said:Apr 3, 2019 11:35:44 GMT 2 freemari said:
You don’t want to do this the antennas are in the straps
It is difficult to remove the back plate.
