LEMFO LEM8 - New model for November 2018.
Hello! Who know how change “always on screen” watch face?
Dec 17, 2018 21:24:16 GMT 1 timka said:
Hello! Who know how change "always on screen" watch face?
I don't have the watch but I don't believe you can. It is designed to work with minimal battery consumption. One of your regular watchfaces "always on" would cause excessive battery drain. This is a relatively new feature created probably because of customer demand for an always on feature.
I could not find how, if it's changeable... Instead I'm adapting a watch face to mimic the actual ambiant one with the options I want to have...
I believe you can change it if you use the universal launcher
You can’t change the stock always on face.
With Eric’s launcher you can use any face and keep the screen on however it uses a little more power.
hi,
i buy smart watch lem8.
i heve lital problem thet i am left han, so my watch in the right hand as that result the camera is. reverse to the body.
ther is any solution to the left hand?
and anther problem the is no notification on my watch when at the time thar is on my phone.
Dec 19, 2018 14:08:50 GMT 1 roeeaveram said:
i'm also left hand and i put the watch on my left hand and i also have a watch on my right hand:) if you want to use the camera your solution is to put it on your left hand. i've tested on all my watches wiiwatch2 and it works fine and perfectly on disconnections and full notifications. have you paired them via the app wiiwatch2?
hi,
I think I have found a solution you might use, I've tested it on my old x5 plus, however you will need twrp. When you have twrp you should make a change to build.prop by adding the line "log.tag.launcher_force_rotate=VERBOSE" at the bottom of the file. Then after rebooting, in adb shell you should use the command "content insert --uri content://settings/system --bind name:s:user_rotation --bind value:i:2" That's it
Or you could try searching for some app on play store
The microphone is very bad … talking without bluetooth headset is not possible. The battery lasts about a day in standby mode. And if you make calls, use the interface … then the charge lasts for 2 hours.I want to return the goods and demand a refund.
The seller does not answer questions about the battery …
Sounds like you got unlucky there.
This is unusual behaviour for this watch.
Can you perform a factory reset and see if it helps?
Dec 20, 2018 15:25:29 GMT 1 timka said:
The microphone is very bad ... talking without bluetooth headset is not possible. The battery lasts about a day in standby mode. And if you make calls, use the interface ... then the charge lasts for 2 hours.I want to return the goods and demand a refund.
I did not figure out how to do a reset, but I was completely re-install the firmware ... it did not help.
using the watch in open space will never result with great voice only in closed spaces and when you mean using it for calls how long the calls? again this is a watch which not come as a replacement for your watch i do about 15min of calls and i get a full 24hrs of usage. it is all about your kind of usage.
The battery is discharged and without calls pretty quickly … just from the fact that I go through the menu.
I have already opened a dispute because I do not need a watch if the charge is not enough even for one working day.
On the forum that created the topic dedicated to Lem 8.
Many users are not satisfied with the problem of quickly discharging the accumulator and more and more of those who, like me, demanded a refund.
Almost everyone bought a watch on sale 11.11
LEMFO LEM 8 - Обсуждение - 4PDA
Even more people after reading such reviews simply will not buy this watch.
I think with this something needs to be done, and not to say “about space”.
I have my lem8 and I only turned on gps and BT and nothing else and so far battery life is really good that is just impossible that yours discharge just from “sitting” around have you installed anything? What connectivities you have been using and for what?
Bluetooth headset and wifi in case anyone calls on “whats app” and sim card, and that’s it. But also from the fact that I just scroll through the menu … the battery still quickly discharges. For example, 2% for 7 minutes.
I left it fully charged for the night, and 43% remained in the morning … but at night nobody used them.
The battery gives up the first half of the charge quickly, and then it discharges more slowly.
Reset the watch and use it inly with wiiwatch 2 and test battery life if you still have issues see if your watch is up to dste if not look for ota updates if it says “it up to date” then flash it with the latest firmware. After that use only wiiwatch2 and test the watch and if you still having issues plz notify here.
I must say that this is very strange.
Everyone I know who has one of these - including me - is amazed at how long the battery lasts…
What is your firmware version?
I flashed the clock with this firmware
“http:///thread/2937/lemfo-lem8-z29-m6739-16gb”
I did not install any and did not use any wiiwatch2.
But the problem is still there.
What else can I do?
Did you reset the watch after the flash?
I flashed the clock with this firmware "http:///thread/2937/lemfo-lem8-z29-m6739-16gb" I did not install any and did not use any wiiwatch2. But the problem is still there.
I of course rebooted the clock-button on the case.
