lemfo lem7
hi is there any problem with wiiwatch2 connection today i recive an update it look like there is a problem when i connect my lem 7 after one minuts it will be disconnected when i go back to wiiwatch 2 it connect again
reset the watch and start all over, are you using more BT apps when using wiiwatch 2?
hi its look like the problem from wiiwatch2 coz when i open it ask me to give permition what you think
i reset the watch same problem is it compatibal with samsung a8+
maby the new ver of wiiwatch2 not compatibal
the wiiwatch2 go offline after 1 minut when i open it again it connect
i test the problem when lock screen turn off the wiiwatch2 app go offline what we can do?
*** plz edit your last comment you do'nt need to make multiple comments especially when you are the last.
i’ve tested the new wiiwatch with my phone and it works fine, have you paired the watch and the phone? if yes unpair them, you only need to connect them via the app and do’nt need to pair them via BT. second uninstall the app from the phone and reinstall it and try again.
dear friend thx for your hellp i did i unpair both blutooth and conected via app but the problem is the wiiwatch app it go offline on screen lock i dont no y i cant use my lem7 coze i cant recive notifucation it was working good when the wiiwatch was on ver2.1.1 i dont no what can i do i just recive my watch lest week and use it
i see what is the problem:) go to saving mode and change the settings there to make sure that the watch wo'nt go to sleep when screen is off.
hello i didnt find save mode my mobile is samsung A8+ can u hellp
settings - power saving - turn it off.
mmmm i didnt find it mabi other thing thx
thx for ur hellp dear
on  the watch? it is'nt on the watch?
Update 2.1.3 is released for WiiWatch2.
Seems ok so far.
Hello friend Van u help me my watch lemfo lem 7 but ia error’ on touchscreen can give solution i already flash with v2,4 but still problem please help me
Jul 1, 2018 8:13:35 GMT 1 lemfo7ce said:
Hello friend Van u help me my watch lemfo lem 7 but ia error' on touchscreen can give solution i already flash with v2,4 but still problem please help me
did you make sure to use upgrading when flahsing the 2.4 version?
