Lemfo lem7 display problem
I have one problem of my Lemfo lem 7s touch is not working lower portion of screen would any body help me in this issue thanks
look at device info about the firmware of the watch and flash it again with it's firmware also the area where the touch still not working that means maybe touch calibration needed or it is hardware problem in my opinion you should replace it.
look at device info about the firmware of the watch and flash it again with it’s firmware if the erea where the touch still not working that means maybe touch calibration needed or it is hardware problem in my opinion you should replace it.
Thanks Sonia
