Sept 20, 2018 1:38:53 GMT 1 peppe said:
Hi everyone, some of you have bought the glass protection. And where?
www.aliexpress.com/store/product/Smart-Watch-Extra-Transparent-Screen-Protector-for-Backup/1095026_32843425089.html
i hope they will produce tempered glass protector cos it needs it, i have screen portector on it but do’nt think that is enough:(
the problem is that the bazel of the watch is very thin and that make the screen more fragile, if i did’nt have screen protector (tempered glass) on the kw99 most likey today the crack on the protector would have been the screen itself, i know that if i had one on my lem4pro it was fine even after the flat fall.
Sept 20, 2018 18:00:16 GMT 1 soniasophie9697 said:capt jon
Watch the shit, do not buy. On the second day, the bank refused, after 2 months screen. The lower part of the screen does not respond to touch, the screen is working phantom. Chas is not mochil.Pri washing hands always took off. I do not have one, but very much. I threw money into the wind. Very sorry.
I have a Finow X5Air for more than a year working without problems.
Sept 25, 2018 15:16:21 GMT 1 dinatron said:
Watch the shit, do not buy. On the second day, the bank refused, after 2 months screen. The lower part of the screen does not respond to touch, the screen is working phantom. Chas is not mochil.Pri washing hands always took off. I do not have one, but very much. I threw money into the wind. Very sorry. I have a Finow X5Air for more than a year working without problems.
This is not my first watch, and I put all the firmware on Lem 7. I staked and firmware from Thor 4, but the screen on all the firmware behaves the same. The sensor does not work at the bottom of the screen. There are phantom inclusions of the screen, when using the keyboard it is impossible to use the bottom one register.
as you said you did try other firmwares and still nothing, so have you considered the possibility that your watch is a faulty one? where did you buy it and when?
The watches were bought in July in the official store of Lemfo on Ali
No. No. a week ago.
Sept 25, 2018 18:36:07 GMT 1 dinatron said:
No. No. a week ago.
ок Спасибо
Sept 25, 2018 18:39:51 GMT 1 dinatron said:
ок Спасибо
Actually, it’s more important to know which firmware it came with originally.
the firmware was v.1.0. Yesterday I put Lem 7 v.2.4 but also the lower case of the keyboard is not available, the touch at the bottom of the screen does not work. Thor 4 put the one that you posted on the forum. Thanks
I have this firmware and I will upload it soon.
This explains why your screen is not working correctly. Your screen will not work with the firmware you found here because they have only just told us about the new version.
It will take a while to upload it.
Tomorrow should be ok.
Thank you very much Pablo will look forward to
Hi, my LEM7 originally had v1.0 nhh but now I run v2.5 with no trouble, I wasn’t aware of the difference before I flashed. The battery life definitely improved alot with 2.5 though.
Still, having v1.0nhh for download would be useful!
