Jun 9, 2018 14:05:11 GMT 1 soniasophie9697 said:
Jun 9, 2018 14:00:14 GMT 1 treazer said:
hey pablo :slight_smile: are you available for teamviewer? i already downloaded the 2.2 version
hey, if you can wait till tommorow i will help you with flashing the watch:)
Hi Sonia,
If you can help it would be great.
It’s 11pm here so I can’t do it.
Just make sure you have read what I posted in the firmware post.
You have to reboot the watch while it is connected to the pc to flash it.
Just make sure all drivers included in the zip are installed and use the flash tool in the zip.
So you click download on the flash tool and reboot the watch while it is connected.
If in any doubt at all we can wait until tomorrow.
Pablo
i tried to install the USB driver but its always failed (windows 8.1)Ā Ā Ā Ā
treazer
about my 3pm or 4pm.
Jun 9, 2018 14:14:45 GMT 1 soniasophie9697 said:treazer
ok i try to make sure to be home then
Hello everyone.
Can anyone help me how to connect lemfo lem7 with iphone7.
I am not able to make calls from my iPhone through Lem7.
thanks
Hello, I’m Stefano from Italy.
I’ve recieved lem7 only two days ago, but it semms to me that there are a lot of problem:
  1. on my Samsung A8, the wiiwatch2 app reset every time tries to connect to watch.
  2. After about two hours of work, the touch screen stop to work and I can only press the lateral button to swich from the clock and the reboot menu. But the the touch doesn’t work, so I cannot reboot (!!!).
  3. I’ve found that if I press for a few seconds the only button, the watch reboot. But also after the reboot, the touch screen sometimes works well, sometimes seems to respond with delay.
  4. The only way to restart the correct use of the watch is a full reset (!!!)
I’m very sorry beacause It seems to me that this could be a great smartwatch (if it works). I give it back to amazon tomorrow, but I would like to buy again this watch (I hope his only my watch that had problem, but is strange that after a reset all works fine).
Anyone had problems like mine?
sakurambo
no, i have this watch also new and do’nt have this problems most likely it is a software problem but you can’t take a risk that it is’nt so it is better to get a replace it is a great watch, i’m going to do some videos on it. great battery life and works well with any activity app.
Hey Sonia, i am sry for being late. I am available now please check your inbox :slight_smile:
Jun 10, 2018 13:45:56 GMT 1 sakurambo said:
Hello, I'm Stefano from Italy. I've recieved lem7 only two days ago, but it semms to me that there are a lot of problem:
Watch has been OK for me. Wiiwatch2 works however I find it is very chatty over bluetooth and massively drains the battery even though I filter most apps.
GSAM is telling me bluetooth is responsible for 83% of my battery usage when I have it enabled.
Would recommend Watch Droid as it seems to be much more battery friendly.
greenie have you flashed the new firmware?
Pablo11, were there changes in 2.2 firmware for the wrist gesture to turn on the screen?
I still find does not work well… many times it does not turn on, and when it does it lags considerably.
Universal launcher is a bit better but doesn’t look as nice and still lags for me. Do you have the same?
Jun 10, 2018 19:07:50 GMT 1 soniasophie9697 said:greenie have you flashed the new firmware?
Yes have been running for 2 days now and seems to be fine and stable. Auto-sync there so I can at least get my contacts on now and keyboard is a bit nicer. Still some fixes to do - screen gesture, NVRAM error, but mostly OK. Would like to root  and do some further optimisation and clean up but Magisk Manager crashes for me when I try to patch the boot image unfortunately.
did you reset the watch before flashing? do you have custom recovery?
I did factory reset after flashing. No custom recovery. Did not flash preloader as pablo mentioned but flashed the rest.
greenie
wait for my video on how to flash recovery and root the watch.
Jun 10, 2018 19:31:31 GMT 1 soniasophie9697 said:greenie
OK - do you have access to TWRP recovery image for LEM7? If so, don’t need video.
soon:)
who knows when the OTA update for our watch will bee?
While nobody is engaged in this and most likely will not do it, because there are possible mistakes when downloading such a loan.
Hold tight, an OTA is coming to fix the NVRAM error. VERY SOON!
The NVRAM error is due to non persistent mac address for WiFi.
The OTA will fix the Mac address which in turn fixes the Google Play store issue with paid apps.
Also fixes auto updates etc…
A7 is much more secure than 5.1 so this is a new problem.
I am fixing up the recovery to use for us as well. Still a few tweaks needed for until I release it.
Pablo
