Sorry, but I just want to make sure - are you saying that you have reset the watch completely - already?
Just now I did the next time reset all the settings, it did not help! all remains the same, there is no question mark above the qr code
âŚFELP!!!
I will have to talk to you tomorrow about this.
Itâs late here in Australia so I will contact you tomorrow and if needed I will use team viewer to access your pc to show you.
Good night.
Jun 7, 2018 13:30:41 GMT 1 pablo11 said:
I will have to talk to you tomorrow about this. It's late here in Australia so I will contact you tomorrow and if needed I will use team viewer to access your pc to show you. Good night.
Thank you so much!
Hello - For always on display - I checked and downloaded âAmoled Screen Always Onâ but it doesnât work properly.
Can anyone recommend a âsmartwatch specific appâ for âAlways Onâ screen⌠Not really a âSmartphoneâ app?
Jun 7, 2018 16:53:06 GMT 1 ashishaggarwal007 said:
Hello - For always on display - I checked and downloaded 'Amoled Screen Always On' but it doesn't work properly.Can anyone recommend a âsmartwatch specific appâ for âAlways Onâ screen⌠Not really a âSmartphoneâ app?
iâm not sure it worth it cos these apps seems to consume faster energy so they will have great impact on battery life.
this one should also be good for watches but tried on my kw99 and wasânt great.
play.google.com/store/apps/details?id=com.smartwatch.amoled.smartwatch
Personally I would never use the always on display. It is a real drain on battery. I am looking into a better screen wake driver for the sensor. But it might take a while.
pablo11 have you returned?
help me with the firmware?
Im just up and off to workâŚ
I do have a real life as well
Otherwise me and my family would be homeless⌠lol.
Iâll be back home later
Otherwise me and my family would be homeless.... lol.Iâll be back home later
I understand you, đI also work very hard!)) if you have a file with firmware-just send it to me, I'll try to flash this miracle clock ...
As I said last night. Itâs not a firmware problem.
Everyone else has the same firmware. I will check yours later using remote control to see what the problem is.
By the way - which country do you live in?
Jun 7, 2018 22:15:21 GMT 1 pablo11 said:
As I said last night. It's not a firmware problem. Everyone else has the same firmware. I will check yours later using remote control to see what the problem is. By the way - which country do you live in?
I am from Russia! we have a forum, and there are many complaining about exactly such a problem! I'm sure that this is a bug in the firmware, but I do not know where to get the file for flashing the clock!đ˘
Iâll have a look tonight when I get home and if I think it is firmware we will fix it up.
Ok?
Jun 7, 2018 22:35:52 GMT 1 pablo11 said:
I'll have a look tonight when I get home and if I think it is firmware we will fix it up. Ok?
Big thanks!đť
I just received mine yesterday. So far I like it with the exception of the wide black edge around the watch face (no edge to edge display).
The only 2 issues that I am having are: 1) Screen would not wake up when using the Raise Hand gesture (Brigthand in this version). I am using the stock launcher. And 2) Screen doesnât wake either when receiving notifications.
Would like some feedback from other people who owns a LEM7 ⌠If you turn the watch off and put it on the dock (when the dock is plugged and the watch is charging), does it turn on automatically? And if you turn it off, does it turns back on?
The one SmartWatch Ticks have also does this. Pablo, have you received your LEM7 or if anybody can let us know if their LEM7 acts the same way.
The A7 watches are all set to power on while charging.
The development team found an issue with the 6737 A7 build which was causing issues if the watch was charged powered off.
So, yes it is confirmed.
You can power off the watches but if you connect it to the charger it will boot up.
Jun 7, 2018 22:59:02 GMT 1 oscarhmeza said:
I just received mine yesterday. So far I like it with the exception of the wide black edge around the watch face (no edge to edge display).The only 2 issues that I am having are: 1) Screen would not wake up when using the Raise Hand gesture (Brigthand in this version). I am using the stock launcher. And 2) Screen doesnât wake either when receiving notifications.
Screen wont wake either way when you recieve a notification on stock launcher . Try installing universal launcher for raise / screen wake . It sort of half improves problem ![]()
I always use Heads Up Notifications from the play store.
It should wake up the screen.
Jeez, itâs frustrating that I donât have a test watch
Good Morning Pablo,
my name is Tom and I am from germany. I have a big issue with my Lemfo LEM7
I got it 2 days ago and now the screen isnt working anymore. I was checking some watchfaces directly on the watch and then the screen turned black. I only can reboot the clock or turn it off. Everytime when i am restarting the phone its the same issue. Black Screen.
I have contacted Lemfo but nothing. Now i found you.
Are you able to help?
Thank you for all your assistence. I really appreciate
Best regards
Tom
