Yep, when the issues are fixed I will make it available for everyone. :+1:
Hi there, I am new to this forum and I just found it through the WiiWatch 2 app. I have a Lemfo 7 from Banggood and so far I like the watch. It was expected to have some issues as the firmware develops but the greatest problem I found was that my language is not supported. There is no Dutch in the additional language settings as advertised.
I contacted Banggood about it and they get back to me.
I also saw the youtube movie (Smartwatch Ticks) on the fitness not using the GPS signal.
So if there is anything I can do to contribute here just tell. I presume there is no working around for the language question as I cannot use voice navigation in Maps at the moment…
May 26, 2018 16:28:30 GMT 1 barnowl said:
welcome:) as the system language?
pablo11
This morning my lem7 arrived.
The smatr version xD
By now There are no Problems.
Works perfect with watch Droid.
O2 Germany works with 4G
I loved my les1 but now it feels like slow old crab in comparison.
Les1 charging dock does not Work with it.
Speaker is loud enough even If the placement is a bit unexpected.
Nice watch!
pablo11
Thank you, and yes, as the system language.........
O, one more thing, is there a way to start Google Fit? It installed ok but I cannot get past the welcome screen as my buttons are not visible.
I want to test the fitness/GPS thing.
My current firmware is Z28LEM7-V1.5
pablo11
For Google Fit, Ibelieve you have to put you watch in square mode (hold the ā€˜power’ button and change the circle to square type screen). That’s the way I did it.
barnowl
about the language let me check, to reach certain buttons you need to change from round to square display mode as been suggested:)
I am checking about the language and I’ll update you soon.
Google fit will install but I very much doubt that it will communicate with the sensors on this watch.
Splen - have you found any fitness apps that you would recommend for the LEM7?
Played around with WiiWatch2 yesterday with native connect software on Lem7. Has anyone been able to suppress notifications for system apps? Does not seem to be possible through WiiWatch 2 UI.
If you are using Android you can go to the app notification section on the phone app and disable all the unnecessary notifications.
Unfortunately IOS support is not good at the moment…
How do you change the units to imperial on the watch?
krapulant,soniasophie9697 and pablo11:
Thanks! Got Google Fit working! Pablo11, if you find a solution to the language problem I’ll be grateful. The reason I have started Google Fit is that I have my fitness history on there. But if you find a good working (GPS connection) fitness app I’ll try it.
Actually it’s the first time I bought a Smartwatch, it was the price, Android 7 and support of 4G (band20) in my country. I have been into modding cell phones since a long time but this watch is something new…
I had to order a duo-sim from vodafone wich is in the mail.
Keep you posted!
barnowl
have you tried to see how Gliderun work with this watch? sadly the developer is’nt responsive and the app is’nt always works well but the heartrate sensor is used by this app, what about heartontop? it syncs with google fit.
May 26, 2018 3:51:22 GMT 1 krapulant said:
May 26, 2018 0:50:52 GMT 1 Splen said:
Went to engineering mode and it says bands supported:
1,2,3,5,7,20
GSM Band modes: 850,900,1800,1900
UMTS modes: 850,1900,2000
Interesting as the Band 2 is not listed anywhere I could find. Band 2 means better coverage than only Band 7 in US and Canada. Sadly I don’t know if it can show which specific band it’s using.
I’m missing the old Nokia Field Test mode…
I used 2 engineering mode apps and band 2 shows up on both apps.
pablo11 AvatarMay 27, 2018 3:42:29 GMT 1 pablo11 said:
I am checking about the language and I'll update you soon. Google fit will install but I very much doubt that it will communicate with the sensors on this watch. Splen - have you found any fitness apps that you would recommend for the LEM7?
No luck yet
Anyone interested in testing a few fitness GPSĀ apps, click link below:
  1. Ā Ā Everlapp OnTrack GPS Fitness TrackerĀ
  2. Ā Ā Fitzeee Walking GPS fitness tracker & Step CounterĀ
  3. Ā  Nike+ Run ClubĀ
  4. Ā Ā Fitness22 Running Distance Tracker +Ā
  5. Ā Ā Lamon GPS Running TrackerĀ
  6. Ā Ā Caledos Runner - GPS Running Cycling WalkingĀ
  7. Ā Ā Caynax GPS Sports Tracker - Running, Walking & CyclingĀ
  8. Ā Ā Endomondo - Running & WalkingĀ
  9. Ā Ā Walk with Map My WalkĀ
10.Ā Saul Cintero MoveOn - GPS Running & Fitness
NOTE: Ā  These are simply apps on the google play store that maybe compatible with the LEM 7 smartwatch.
Thanks Splen :+1:
May 27, 2018 19:23:33 GMT 1 soniasophie9697 said:barnowl
I have just installed and looked at Gliderun, it work on the watch but very limited, even with square display I am not able to sync with Google fit, the button is hidden.
Use chrome browser on your pc. Enable usb debugging Install a plugin called VYSOR in Google Chrome. Connect watch to pc and run Vysor. It will give you access to the watch and allows access to the buttons.
May 27, 2018 20:48:25 GMT 1 Splen said:
Anyone interested in testing a few fitness GPS apps, click link below:
  1.   Everlapp OnTrack GPS Fitness Tracker
  2.   Fitzeee Walking GPS fitness tracker & Step Counter
  3.   Nike+ Run Club
  4.   Fitness22 Running Distance Tracker +
  5.   Lamon GPS Running Tracker
  6.   Caledos Runner - GPS Running Cycling Walking
  7.   Caynax GPS Sports Tracker - Running, Walking & Cycling
  8.   Endomondo - Running & Walking
  9.   Walk with Map My Walk
10. Saul Cintero MoveOn - GPS Running & Fitness
NOTE:   These are simply apps on the google play store that maybe compatible with the LEM 7 smartwatch.
I have just installed  the fitzeee app and everything seems to be working properly.
