That is true. The review is good and actually looks like some commercials. But with no cam and no wcdma 1900Mhz, I’m out. The slot for the sim is great. The pins for charging might get corroded or weak with the sweat …
yeah, true.
for the pins, while i had the same, i would always recommend some soldering on the pins. after that corrosion will be much less and there will be no problems arising.
but it’s a lot of tinkering around with those watches.
i also wonder, why the pins (a very essential part on the watch since it is used for charge and data) are of such poor quality.
like i say, i still wait for some ‘high quality’ full android watch (i don’t need a cam, but i like to have things like always on display (yeah now i’m crazy about this, since i have it on my lg and run so easily through 24hrs), good battery life, advanced sensors and stable software.)
I do have lem5 (older one) which is also IP55.
So, it looks like we have pretty much maxed out on IP rating for the US frequencies?
Shame lem6 doesn’t have 1900.
I hope so. While not as good looking as an H1 (and no camera! boo!) this thing nicely made!
i like it's look the only DOWNSIDE of the watch is that it is'nt waterproof:/ not even ip67.
Ah yes! My only other gripe with the H2 is the lack of changeable bands.
The H1 gets around the need for antennas in the bands by using a pair of pogo pins off the main circuit board to contact metalised printed antennas on the inside of the casing. The BT/Wifi antenna is just a short piece of wire soldered to the PCB.
Interestingly the Lem6 instructions specify you cannot use a metal strap. I wonder if they are using the springbars as the antenna?
Hi . Can you confirm what battery is like before you changed things ? Would it be safe to say you would get a good day from it ? Whats GPS like . Thankyou
Dec 17, 2017 7:45:53 GMT 1jinvice said: I did some things with my lem6, for now it look like to be able to stay on 3 days with one single charge with low usage. With a custom kernel i am sure i can push it to 4/5 days or 2/2.5 of average use.
Changelog:
-removed lemfo bloatwares
-replaced gapps with more power efficient alternatives
-set cpu clock to 600mhz
-replaced stock launcher with tsf
-changed buttons fuctions
-gained root
The dream will be reach 2 days of 3g. Need to access partitions to say what is possible and what not. I am sure lemfo engeneers did a bad work as always.
With a bit of luck i will release a custom rom
Dr Vishnu
BEFORE: 8%/hour with everything off. Screen on was draining so fast battery,
AFTER: 2/3% drain/hour with everything off. (more near 2%). Screen on is drainig normal amount of battery.
I don’t know about multitouch, i know that lemfo les1 had it and it was removed in many updates, i think lemfo disabled it due battery drain, but in my opinion the difference overall is abot 5% difference, maybe there is a way to turn it on if display support it.
GPS: is ok,but has bad connectivity indoor.
-verything seems to work fine, only huge difference is that apps won’t be downloaded from gplay.
-Usability improved. Stock music player was replaced with Stellio.
-i setup apps to auto-freeze themself after i close them.
-many receivers was disabled
-System stability is much better. ZERO system freeze, ZERO lag.
-(i can provide a detailed guide to let gapps on if you need them, but without any process in background)
Dec 17, 2017 9:47:18 GMT 1Tim And Pierce Collins said: Hi . Can you confirm what battery is like before you changed things ? Would it be safe to say you would get a good day from it ? Whats GPS like . Thankyou
Dr Vishnu
