Hi.I bought a watch 01.03.2018.Decided to flash because of the rapid discharge of the battery. to flash custom ,with my revision W618 mv v1.0. it is not understand why got bricks.
I try to many build on your forum. Error one and the same S_FT_ENABLE_DRAM_FAIL.
Drivers - MediaTek USB Port
Is it include or not to clamp the driver to appear - MediaTek DA USB VCOM (Android),
but nothing happens in FT,there are no errors, the stop button hangs
Help Me please
Mar 5, 2018 21:21:32 GMT 1 Demonzvz said:
your watch is lem5 and not the pro?
Lem5 1GB 8GB. Dont PRO.I need some new version preload.I try many different preload,but they dont work
there are to models the w618 and the w616 on the firmware section there is only the w616 of the lem5 not the w618, you need to flash the x5+ w618 on your watch and it will work perfectly.
but be sure that your watch IS the w618 it should be written under the back cover in the watch.
The back cover in the watch written w618 v1.0
I try w618_wgl.x5plus_ddr3.common.80.emmc.w.s.170111-152721
w618_wgl.x5plus_ddr3.common.80.emmc.w.s.170327-183955
w618_wgl.lemfo_ddr3.common.80.emmc.w.s.170306-124543
Error one and the same in FT S_FT_ENABLE_DRAM_FAIL (4032). Watch I think with the latest firmware. Need other new
I have watch 2018 years,fireware need latest where can I get?Help please
you can't flash the watch with every firmware you see some of them are updates and not the stock firmware. you need to flash it with the stock. the w618 model.
i will see if we can get the lem5 pro firmware.
you can’t flash the watch with every firmware you see some of them are updates and not the stock firmware. you need to flash it with the stock. the w618 model.
i will see if we can get the lefirmwarem5 pro firmware.
where to get Stoke the firmware on my version watch?the old one didn’t match. I try w618 1.0,they dont work.
I have watch Lemfo LEM5 (w618 - 1Gb DDR3, 8Gb) 1.0
@demonzvz
this the only one for your watch: /thread/543/w618-version-firmware-watches-memory
sorry, we do’nt have the lem5 w618 i will check with the developers if we can get also the w618 but for now you can use the x5+ cos they are the same model.
the one that you got is’nt put on the forum by us cos we can’t check it out because we do’nt have this watch.
Mar 10, 2018 15:31:02 GMT 1 soniasophie9697 said:
@demonzvz
I tried to put x5 + error 4032
@demonzvz
have you tried other firmwares? that sounds like problem with preloader but it should'nt be an issue as the x5+ and the lem5 are the same watch.
have you made sure that drivers are installed? usb mtp? do them again.
On 4pda by all means tried to help, any firmware, preload, even formatting issues a 4032 error. Say that died in the flash memory is after 1 failed firmware. On 4pda write need donor my watch to flash “Write Memory”. Backup need only one region EMMC_BOOT_1 its size 0x0000000000400000. Maybe someone has a backup lying around?
have you tried other firmwares? that sounds like problem with preloader but it should’nt be an issue as the x5+ and the lem5 are the same watch.
did you try to install again drivers ?
Of course the versions are different FT, any action of any ft gives error 4032
if you installed the drivers and usb mtp and the cable is fine then you should be able to flash. remove drivers and reset the watch and start all process again i use an old version of SP.f.tool. i use v5.1644
Sent back to the seller aliexpress, service center has determined the diagnosis - killed Flash memory and this watch is only bought
I have the same problem. 4032. Did you find the problem?
